ABS Light Randomly Came on?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Jul 7, 2015.
  1. Jul 7, 2015 at 9:55 AM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey guys,
    So this past weekend I drove down to the shore and no lights on my dash were on. The day after I came back ABS light came on when I started the truck up on the way to work. It was dry out that morning, but it rained that night. Today, the light came on again when I started the truck up, and it rained last night a little bit as well.
    I have had it come on when it is wet, or snowy out, but my question is if it is dry outside like today what could be causing it? And how do I fix it?
    thanks
  2. Jul 7, 2015 at 12:57 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Check the code, if it comes back as 31, 32, 33, 34, 35, or 36 the sensor or teeth are probably dirty. Remove the sensor, wipe off any crud and look in the hole. I used a little flat head screwdriver to clean the gunk out from between the teeth.
    Code list.
    ABS Codes.pdf
    skidrow likes this.
  3. Jul 7, 2015 at 7:57 PM
    Tjsingle26
    Tom
    PA
    Checked for codes and nothing...
  4. Jul 8, 2015 at 12:22 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    You have to check it when the light is on and you can't get them with a regular cel code reader.
    But if it's intermittent during wet times I can almost promise that one is dirty. Probably water and dirt getting by a dry o-ring on the sensor.
    They are easy to take out.
    Front: Remove the wheel and you can see it on the hub. They are only held in by one bolt, then wiggle the sensor out. Just pulls straight out.
    Rear: remove the wheel and you can see the sensor. The rears can be unplugged at the sensor so do that to avoid any wire strain. Then pull them straight out.
    Once out wipe the end off with a rag and get any little metal flakes. Look in the hole and clean between the teeth with a little screwdriver.
    Grab a few new rubber o-rings if yours look bad or came out rough.
    McFlysRide likes this.
  5. Jul 29, 2015 at 4:27 PM
    Tjsingle26
    Tom
    PA
    Okay, so I looked at the sensors and they looked fine. Rubber was good, any metal specks that were there I cleaned out. However my ABS light is still on :( Not sure what to do?
  6. Jul 29, 2015 at 10:08 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    I'm not sure where your OBD port is, as I think the location changed after a certain year. BUT, mine is below the steering wheel.
    Grab a paper clip and jump connectors 13 and 4 with the truck turned off.
    Turn the truck on and watch the ABS light. It will blink for 2 numbers with a pause in between. Ex 5 blinks-pause-1 blink = code 51. Once you have the code, then you can start somewhere.
    Like snowman said, a regular OBD scanner won't pick up the ABS codes.
    source : http://www.justanswer.com/toyota/4gwq1-toyota-tacoma-4x4-2002-toyota-tacoma-4x4-3-4l.html#
    Snowman likes this.
  7. Jul 30, 2015 at 2:47 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    I had this issue a few years back and I wasn't getting any codes. I took it to a local Toyota mechanic who unplugged the rear ABS sensors, blew them out with air and plugged them back in. The ABS service light went out and hasn't come back on since.
  8. Jul 31, 2015 at 8:36 AM
    Tjsingle26
    Tom
    PA
    Paper clip safe to use as a jumper wire? I also noticed the fuse cover had a crack in it, but the actual fuse looks fine. Could this be a source of my problem?
  9. Jul 31, 2015 at 4:59 PM
    Tjsingle26
    Tom
    PA
    Alright, so I used the paperclip today, tried to reset the ABS and it still threw the code. I got a 34 code, indicating the left wheel sensor. I already checked the sensors, made I should just check that one again?
  10. Jul 31, 2015 at 5:21 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I would check it again. Make sure it's clean as well as the plug. Then follow the wire back to see if there is any visible damage.
    Worst case a replacement rear sensor isn't super expensive.
  11. Aug 29, 2015 at 2:38 PM
    Tjsingle26
    Tom
    PA
    Welp, I cleaned the sensor again. Nothing, still throwing code 34. I did follow the wire and I didn't see anything abnormal. I am guessing the sensor is dead? I dont know what else to try.
  12. Sep 2, 2015 at 12:31 PM
    Tjsingle26
    Tom
    PA
    Anyone?
  13. Sep 2, 2015 at 11:55 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Seems that way.
    Throwing a code for a bad sensor. You cleaned and inspected the line and sensor which didn't work, so a new sensor is the next logical step.
  14. Sep 17, 2015 at 12:08 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Or you can puta meter on the sensor and see if it gives you a reading. Also you could put it in and turn the wheel with the meter on ac and see if it give you a reading while spinning the wheel by hand. Only reason I know is because I am trouble shooting also.
