Abs light reset!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ahougland89, Mar 4, 2016.
  1. Mar 4, 2016 at 3:11 PM
    Ahougland89
    Ahougland89 [OP] Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    Recently changed my wheel bearings out which needed to be done. Now ABS light won't turn off. Anyone know if there is a reset?
  2. Mar 4, 2016 at 8:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Double check your wheel speed sensors. One must have gotten damaged during the bearing replacement. It should reset itself when the issue is repaired.
  3. Mar 4, 2016 at 8:42 PM
    Ahougland89
    Anthony
    Orting, Washington
    Well abs light was already on...where are my wheel speed sensors? Thanks for the help
  4. Mar 4, 2016 at 9:33 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  5. Mar 4, 2016 at 9:40 PM
    Ahougland89
    Anthony
    Orting, Washington
    So just check those clips where they plug in?
  6. Mar 4, 2016 at 9:43 PM
    Lester Lugnut
    I would also check continuity of the circuit.
  7. Sep 13, 2019 at 7:31 AM
    CanOfRockstar
    CanOfRockstar Active Member
    2012 Barcelona Red TX Pro
    some of these threads are useless....
