ABS light with right turn signal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jfisher, Jul 18, 2012.
  1. Jul 18, 2012 at 8:25 AM
    jfisher
    jfisher [OP] Active Member
    so recently i noticed my abs light will come on while driving, but only while i put the right turn signal on. when the light is on and i shut the truck off and hit the lock button, the headlights, turn signals, and brake lights will all flash instead of just the turn signals. anybody have this happen?
  2. Jul 18, 2012 at 8:32 AM
    jfisher
    nope, i haven't wired anything into the truck in about a year. i'm thinking maybe a short somewhere?
  3. Jul 18, 2012 at 5:23 PM
    jfisher
    after going for a drive today i figured out that if the brakes are on when i put the right turn signal on, the abs light comes on only after i let off the breaks. if the breaks aren't on when i put on the turn signal, the abs light comes on within one or two flashes of the blinker. this is only with the right turn signal, the left has no effect on the abs light. any thoughts?
  4. Jul 18, 2012 at 6:28 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Do you have the 7 pin trailer socket? If you do, I'd check there for mud or corrosion shorting the pins, and for any damage.
    The brake light circuit is an input to the ABS, and if it got a low voltage input from a short it could cause a fault and the light to come on. A bad ground to one of the taillights could do it too.
  5. Jan 5, 2020 at 11:46 AM
    Anthony7a
    Anthony7a Active Member
    2nd gen tacoma
    Any one ever figure this out?
  6. Jan 17, 2020 at 8:32 AM
    Pancho72
    Pancho72 New Member
    Francisco
    I just notice this in my 2003 tacoma, I will try the trailer lights connections, first.
  7. Jan 18, 2020 at 7:49 PM
    Anthony7a
    2nd gen tacoma
    I need to look into mine since I have the issue and had u hual install my towing package so not sure how they wired it
  8. Jan 22, 2020 at 10:36 AM
    Pancho72
    Pancho72 New Member
    Francisco
    I installed a tow wire harness a few years back, I removed the tail lights disconnected and cleaned (dirty) using CRC electrical spray cleaner, reset light with scanner.
    My tow wire harness connects in the tail lights.
    As of now ABS light still off.
  9. Jan 25, 2020 at 9:48 AM
    Pancho72
    Pancho72 New Member
    Francisco
    ABS light again. Round two
    I found debris on the two wheel speed sensors, I believe this is the cause for ABS light.
  10. Jul 1, 2020 at 1:10 PM
    Anthony7a
    2nd gen tacoma
    My trailer wirings ground broke off and finally got it replaced after I kept getting the hyper flashing, but even with the new one I keep getting the flashing on driver side only
  11. Apr 20, 2021 at 5:58 PM
    ry.had
    ry.had New Member
    2008 White Tacoma
    I am also having this issue. I recently got new taillights, which are LED. The turn signals had hyperflash and the abs light would come on. I got two resistors and installed them today, and the hyperflash is fixed. The abs light still comes on after a couple of blinks. If I press the brake pedal while the turn signals are on, no abs light comes on. I do have a tow wiring harness though.
  12. Jun 21, 2022 at 4:51 PM
    arkmm
    arkmm New Member
    2005 TRD off road SOLD. Looking for a 1st gen
    I'm researching for a very similar issue on my 98 LX470. I replaced the brake and turn signal bulbs with LEDs and changed the relay so I wouldn't get the hyper flash. Now when the headlights are are and I use the left turn signal the ABS light comes on. That subsequently will disconnect the cruise control if you are using it and there's also a surge in the engine every time the turn signal lights up, about 50-100 RPM.
    Lots of people saying check the trailer harness so I'm gonna replace that next. There's no telling how old it is since the truck is from 98. If anyone has fixed this let me know.
