ABS light
Discussion in 'Technical Chat' started by stanman9, May 6, 2009.
  1. May 6, 2009 at 3:42 PM
    stanman9
    stanman9 [OP] Well-Known Member
    Toytec co's and aal, tc uca's
    I was installing spacers the other day and when I think I dropped the hub too far and now my ABS light is on. I hope its just that I pulled a wire or a sensor loose. Any ideas?? Any ideas how to get rid of the light without going to the stealership?? 06 4cyl 4x4
  2. May 7, 2009 at 7:54 AM
    stanman9
    any ideas?
  3. May 7, 2009 at 8:18 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Have you looked at the ABS speed sensor wiring harness clips to make sure they're not loose? Located behind the wheel, see PDF.
  4. May 7, 2009 at 8:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What he said^^^^ You could have also broken a wire...
  5. May 7, 2009 at 8:53 AM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Like Chris said I think you broke the ABS wire only way to know for sure is to pull the code more than likely the code will be for that wheel. You will need to replace the wheel sensor and then clear the code.
