ABS light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dow30k, Jan 2, 2021.
  1. Jan 2, 2021 at 4:34 PM
    Dow30k
    Dow30k [OP] Member
    2002 Tacoma TRD
    Manga Flow Exhaust Wrangler DuraTracs
    2002 TRD Tacoma 200k miles. ABS light on, brought to shop to run codes and they did $800 worth of work > forget exactly what they did but it fixed it for a while > light is back on (goes off sometimes- but it’s usually on) and sometimes at very low speeds (under 5mph- not on the gas) the abs will activate/flutter briefly without me touching the brake. Thoughts? I’m hesitant to keep plowing $ into more diagnostics.
  2. Jan 2, 2021 at 4:36 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Do you have a brake leak Are you low on fluid? Keep in mind the master cylinder actually has two chambers and if you're checking the fluid you usually can only mostly see the chamber but the rear chamber could possibly be empty. I've encountered this before myself.
    Also your 2002 is a first gen and you're posting in the second gen section You may get better responses in the first gen section.
  3. Jan 2, 2021 at 4:39 PM
    Dow30k
    Dow30k [OP] Member
    2002 Tacoma TRD
    Fluid is good just dirty. No leaks. I forgot the gen of my truck lol...thanks.
  4. Jan 2, 2021 at 4:56 PM
    Key-Rei
    Key
    Florida
    Are your pads and shoes worn at all?
  5. Jan 2, 2021 at 5:10 PM
    Dow30k
    Dow30k [OP] Member
    2002 Tacoma TRD
    Pads are new. Shoes haven’t been replaced in a while. I know the shop was working on an ABS ring. Are those only up front on the disks or also on the rear drums?
  6. Jan 2, 2021 at 5:28 PM
    Tacoma Mike
    Southern Maine
    You need the codes first before you can even think about repair.
    6 gearT444E likes this.
  7. Jan 2, 2021 at 7:17 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    not likely the chase of your ABS light, but dirty fluid is not good.
  8. Jan 2, 2021 at 8:01 PM
    Key-Rei
    Key
    Florida
    They are in the rear also.
  9. Jan 3, 2021 at 6:54 AM
    badger
    badger Well-Known Member
    07 SR5
    The rings are built into the wheel bearings. You probably have a bearing going bad. Yes they are front and rear.
  10. Jan 3, 2021 at 12:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The first generation tone rings are separate from the wheel bearings ( Passive Sensors ).
    Second and third gens have magnetic tone ring built into the wheel bearings ( Active Sensors ).
    badger[QUOTED] and landphil like this.
  11. Jan 3, 2021 at 12:56 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    Easy way to start is to visibly check all the wires to the sensors if you truck is modified a lot of times they get damaged from install or if someone worked on suspension or brakes and stretch the wires usually by being lazy and not unbolting the sensor harness, usually in that case u can’t see the damage then u will have to check the harness extensions with a voltmeter for continuity. But really need the code to pinpoint problem. Also I have seen were the sensors arnt all the way tight and this can cause intermittent problem. So make sure they are bolted and seated properly and no obvious wire damage, Also u can remove the sensors and clean them metal get stuck on them because they are magnetic.
