ABS module AND wheel sensor need replaced?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marcus, Nov 16, 2015.
  1. Nov 16, 2015 at 2:45 PM
    Marcus
    Marcus [OP] Member
    Mark
    Redding, CA
    2006 TRD Double Cab V6 4x4
    Pioneer 6965r 6x9's in the front Pioneer TSA1675 6.5's in the rear Kenwood Excleon Deck Kicker 200.4 Amp Dual RF Shallow mount Prime Subwoofers
    After the E break and ABS light came on I took my 2006 Tacoma to have it scanned on why. Mechanic says both my abs module and wheel sensor need replaced. Both simultaneously going bad seems strange. 750 bucks out the door seems pricey. Is that fairly common with our trucks? Any thoughts would be appreciated thanks!
    2006 Tacoma 4.0
  2. Nov 16, 2015 at 2:54 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    ABS modules can get very expensive. I've sold some on GM products that can retail for over a grand. However, I haven't heard of this being a common problem on Tacomas or any other vehicle for that matter.
    Marcus[OP] likes this.
  3. Nov 16, 2015 at 4:23 PM
    Marcus
    Marcus [OP] Member
    Mark
    Redding, CA
    It seems weird that both simultaneously went bad...The lights all of a sudden went on after driving in snow for 3 hours. Dealer says abs modules rarely go wrong on our trucks, wheel sensor is common. Original mechanic that scanned the codes contradicts him and says abs modules going bad are very common. Any advice y'all?
  4. Nov 16, 2015 at 4:32 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Based on your 3 hour drive in the snow, I'll bet it's a sensor. Maybe some ice busted a connector or damaged the actual sensor. Just a guess, but I've been in the car repair business for a long time, and I have sold many more sensors than modules.
  5. Nov 16, 2015 at 4:44 PM
    Marcus
    Marcus [OP] Member
    Mark
    Redding, CA
    /\ agreed. The local shop says it's a "coincidence they both went wrong after the snow drive. Sounds a bit fishy...
  6. Jan 31, 2016 at 5:54 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
  7. Feb 14, 2016 at 1:13 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Update for my problem.
    Ok so today I have been trouble shooting my abs codes. Found the problem. One side of the the abs sensor was/is open in the harness. From the plug at the drivers kick panel to the plug at the rear crossbar there is an open. All the harness looks good no cuts or abrasions. I ran a new set of wires from the plug to the other plug bypassing the harness soldered the connections and heat shrunk the joints. Drove down the road and it got the abs lights when off. Pulled over and cleared all data from obd port and went back home. No lights all good.
  8. Feb 15, 2016 at 2:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Big :thumbsup:
