ABS not working
Discussion in 'Technical Chat' started by JDenny15, Nov 19, 2011.
  1. Nov 19, 2011 at 8:35 AM
    JDenny15
    JDenny15 [OP] Well-Known Member
    Bozeman, Montana
    05 Tacoma TRD offroad
    Custom built front bumper, URD true cold air intake, Throttle body spacer, Jardine cat-back Exhaust, URD short throw shift, custom flatbed, rear airbags, led light bars, ooga horn, CB, PA
    so my abs light has been on for a long time now, like months, and i never thought it was a big deal. i took it in to get checked out and they had no idea what it was.... told me its probably a dirty sensor. but it snowed for the first time and when i tap the brakes, all four tires lock up and i slide all over the road. any ideas or suggestions? i was going to check out the sensors by the wheels but don't know exactly which ones they are. maybe a sensor just burnt out? any help would be appreciated.
  2. Nov 19, 2011 at 11:20 AM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    You need to have the codes pulled to start a diagnostic plan.
    Could be anything from a bad sensor to a bad wiring harness to a bad actuator. Once you have the codes there are steps to eliminate problems with the system...
  3. Nov 20, 2011 at 4:53 PM
    JDenny15
    Bozeman, Montana
    figured it out. small cut in the wire going to the sensor
  4. Nov 20, 2011 at 4:56 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    YEA ALL RIGHT
    :D Good for you.......
  5. Nov 20, 2011 at 5:00 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I'd be happy if my ABS didn't work in snow .
    One of these days I have to do Crom's bypass
  6. Nov 20, 2011 at 5:05 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    YEA Like i said before I need to do some experimenting myself with his write up.
  7. Nov 20, 2011 at 5:06 PM
    OZ-T
    Peter North
    British Columbia
    You go first :D
