ABS On A Switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by monsterkx2fiddy, Jan 27, 2017.
  1. Jan 27, 2017 at 2:48 PM
    monsterkx2fiddy
    monsterkx2fiddy [OP] Well-Known Member
    Birthplace of Davy Crockett
    Had some spare time and wired my abs fuse to a switch. Maybe someone can make a write up with pictures?
    In the fuse box under the hood I pulled the "ABS No.2" female fuse/fusible link.
    Take a female spade connector and connect it to some 18 gauge wire. This goes to the post nearest the cab (hot post) of the fuse/fusible link. And run the wire through the cab and to your switch.
    Now for the cold post in the fuse box connect a female spade connector to about 3" of wire where you will connect a male spade connector. Plug the male spade connector into one side of the fuse/fusible link.
    Now take another piece of wire and put a male spade connector on one end and plug it into the other side of the fuse/fusible link. Run the remaining wire into the cab to your switch.
    solder/shrink/tape your wires since they will be exposed.
    Abs On A Switch.
    (In the video my switch is not in the cab as this was temporary for me and just done to help members.)
    02Duck and honda50r like this.
  2. Jan 27, 2017 at 3:02 PM
    monsterkx2fiddy
  3. Jun 9, 2018 at 7:58 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
  4. Aug 28, 2018 at 9:44 PM
    02Duck
    Bump
    Parksareforever likes this.
  5. Feb 4, 2019 at 11:13 PM
    02Duck
    Anyone else try this yet?
  6. Feb 5, 2019 at 12:44 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Was wondering why do this. Abs saves lives
  7. Feb 5, 2019 at 5:31 AM
    02Duck
    There are times it doesn't, especially the over active programming in low traction situations like snow or gravel.
    bulalo[QUOTED] likes this.
  8. Feb 5, 2019 at 5:51 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Ok you have valid argument. Never think of that .
  9. Dec 15, 2019 at 9:28 AM
    02Duck
    Anyone else give this a try? Winter is here
