ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Dec 14, 2016 at 3:08 PM
    #2001
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Ha! Been waiting for this thread to pop back up. Surprised it took this long...
    Torspd and Sig45 like this.
  2. Dec 14, 2016 at 3:33 PM
    #2002
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Figure this thread would reveal itself this time of year.
    :popcorn:
  3. Dec 14, 2016 at 3:58 PM
    #2003
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Good tires and proper braking technique have meant I've only hit ABS once this winter. Last winter with the stock Dungflops it was a different story. Brake early, brake often. Threshold braking works, but the threshold is a lot lower in adverse conditions obviously. I also wonder if the TRD OR trucks are a little more sensitive.
    MTopp likes this.
  4. Dec 14, 2016 at 4:06 PM
    #2004
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I ABS everyday
    MTopp and Arailt like this.
  5. Dec 14, 2016 at 6:27 PM
    #2005
    badger
    badger Well-Known Member
    07 SR5
    I've had my abs disabled for years. Don't need or want it
    bluezzy, agunday21 and MTopp like this.
  6. Dec 14, 2016 at 6:44 PM
    #2006
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
  7. Dec 15, 2016 at 11:28 AM
    #2007
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    IMO, ABS works OK, just much too hypersensitive to being activated................
    MTopp likes this.
  8. Dec 15, 2016 at 12:25 PM
    #2008
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    In other words, it doesn't work. I agree its too sensitive, and because of that it doesn't really try to stop you, its always letting you coast a little rather than trying to brake a little.
  9. Dec 15, 2016 at 2:19 PM
    #2009
    Hairy Taco
    North of Hell
    08 TRD
    It is too sensitive for my preference. Good winter tires have helped to mitigate the issue, but I do not like the ABS on my 08
  10. Dec 17, 2016 at 9:12 AM
    #2010
    TA 4
    TA 4 Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    My abs rarely kicks on for myself. I run 4 aggressive snow tires on my truck. It will kick on if I slam on the brakes, but for the vast majority of the time it will rarely kick on, unless its sheer ice then in that case unless you have studded tires then your up the creek without a paddle.
    We have had about 5-10 in of snow everyday this week with some days of 1ft of snow. Abs hasnt kicked on once.
    All season/terrain tires start losing their grip around 7c regardless of tread design. By the time you get below zero you might as well have hockey pucks for wheels. Even in -30 my snows tires are still soft and pliable.
    MTopp likes this.
  11. Dec 17, 2016 at 10:15 AM
    #2011
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I didn't think mine worked because they never lit up. So, yesterday with nobody on the road, I slammed them on a good straight road on the snow, and by golly I just kept going! Stopped in a straight line eventually.
  12. Dec 17, 2016 at 3:52 PM
    #2012
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    ABS Anti-stop Brake System
    landphil, agunday21 and MTopp like this.
  13. Dec 27, 2016 at 6:38 PM
    #2013
    ChrisMassy99
    ChrisMassy99 Member
    Oregon
    14 DCLB 4x4
    Finally want to do this mod after my displeasure with the ABS a few weeks ago. Are there any updated methods / ways to complete the ABS kill switch? I know of Rodstones and Landphils, sorry haven't looked at this thread for over two years... I've read a little bit about "pulling a wheel sensor," just wanted to see if there is an easier way to accomplish (not that those other write ups are tough)
    2014 SR5 4x4 Tacoma
    Duratrac Tires with Bill 5100 set at .75 and AAL in back and the ABS is still stupid sensitive - in case anyone cares.
    Thanks all.
  14. Dec 29, 2016 at 11:04 PM
    #2014
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    I did the Landphil method and interrupted the light green wire that goes to terminal IB1.
    Landphil used a connector from a wrecked truck and removed the pin from the factory connector to make things a little more reversible. I went about it a little differently and used insulated spade connectors and cut the light green wire. If I ever remove the switch, I just have to unplug what I put in and plug the two spade connectors back together. Just make sure you use a male connector on one half of the cut light green and the female on the other, then put a male and female on the switch loop.
    From there I ran two wires in a piece of loom over to the console area to an ABS Disable pushbutton from AirOnboard.
    You can see it to the left of the USB port.
    Getting here was the worst part of the job. I popped out one of the blanks and started fishing the loom with wire in it through the console. There is a path, just keep pushing and prodding until you find it. I zip tied the loom over to the left side of the truck where the connection is made.
    Nickel and Hairy Taco like this.
  15. Jul 28, 2017 at 3:24 AM
    #2015
    Cgirl69
    Cgirl69 New Member
    Cynthia
    2002 toyota tacoma
    Right now im dealing with my toyota tacoma... My brakes were acting funny..i go amd get new brakes. Went to put them on come to find out it wasn't the brakes my second guess was master cylinder...i get a new master cylinder and its still doing the same thing won't stop the truck... Im thinking its the abs...
  16. Jul 28, 2017 at 5:56 AM
    #2016
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How were they acting funny, more specifically?
    Did you only replace the front brake pads, or rear shoes as well?
  17. Jul 28, 2017 at 7:53 PM
    #2017
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    This thread is talking about 2nd gen perceived ABS issues. Your truck is a first gen. Given its age I would say you need to service the entire brake system. You could have a leak or bad line somewhere especially if the truck still had the original brake fluid.
    Torspd likes this.
  18. Sep 13, 2017 at 5:36 AM
    #2018
    ecliff5
    ecliff5 Well-Known Member
    Brooklyn, NY
    06 Tacoma Access cab
    King Coilovers with Total Chaos stock length upper & lower control arms, Bilstein and Archive Garage shackle flip in the rear Bruteforce Fab Front & rear SOS Offroad Concepts sliders RCI skids 285/75/16 Falken Wildpeak AT3W on Pro Comps Hard Shell RTT and ARB awning on a Pinsu rack Home made storage drawer unit in the bed.
    Need some insight on an issue I'm having with my ABS.
    A few months ago I was out on a trail and my ABS light came on (I was in 4HI, so it shouldn't have disengaged) Checked all sensors and fluid and everything was fine, no damage done on the trail, figured I got a sensor wet. On the drive home it went off, and came back on a few times but ultimately stayed off until this morning.
    I was very slowly coming to a stop sign, 5mph or slower in city traffic and all of a sudden my ABS kicked on (dry pavement) and almost didn't let me stop at the intersection, a minute or so later my ABS light came back on, I did a few hard brake presses and no ABS came on and all braking felt fine. I parked it at work checked all the sensors and fluid and everything seems to be fine, i'll start it up during lunch to see if the light went off.
    Anyone have any experience with this?
    uurx likes this.
  19. Sep 13, 2017 at 8:34 AM
    #2019
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I just wish I knew how to disable mine, I hate the hell out of it.
  20. Sep 13, 2017 at 9:26 PM
    #2020
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Sounds to me like you may of pinched or pulled a wire leading to an ABS sensor. If the voltage going back to the ABS controller isn't correct you get the warning light and at best a faulty ABS system.
