ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Jan 4, 2010 at 8:51 AM
    MO'B
    MO'B Member
    Michigan
    Prerunner SR5
    Could this just be a fundamental disconnect between the marketing/hype that promotes ABS, assumptions possibly being made by drivers as a result, and the reality of Newton's second law: F=mass x acceleration ("The more mass the object has the more inclined it is to resist any change in its motion")?
    Just asking.
  2. Jan 4, 2010 at 8:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    I am not doubting that. I think the system needs tweaking because I have had the ABS fight me at less the 5 mph on my Tundy. I even rear ended some one (idiot was stopped in the road) on a snow/ice covered road. I couldn't gain control of the brakes.
  3. Jan 4, 2010 at 8:57 AM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I agree. Although I think it should be disabled at closer to 10mph or so, I guarantee I was not moving even 5mph the other day when it kicked in. I was at an absolute crawl.
  4. Jan 4, 2010 at 9:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    That seems to be when it kicks in for me.
  5. Jan 4, 2010 at 9:01 AM
    PA452
    Western PA
    Taking away your braking power entirely certainly won't stop you.
    In both examples I typed out, ABS could have caused an accident. And in both examples, had ABS not been there, I would have had absolutely no problem stopping.
  6. Jan 4, 2010 at 9:02 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    I agree the ABS is not the best on our trucks. Hopefully they make some changes to the programming on the upcoming models. It is far too sensitive on the front wheels. Some other manufacturers have changed the logic to allow wheel lockup thus allowing a buildup of sand, dirt, snow in front of the wheels that will assist in braking ability. It's all in the programming.
  7. Jan 4, 2010 at 9:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The system knows the terrain better than you do.... and it shouldn't engage unless a wheel has locked up.
    Like I said before....take the truck to the dealer and have the system checked for malfunctions.
    The fact that you coasted through the intersection was not due to the ABS. You're going too fast to begin with. The fact that you needed to use the brakes that hard to force the wheels to lock up to engage the ABS - says (to me anyway) that you're going too fast.
    Try going a little slower - like 5-10mph slower on these same conditions and report back to use on how the ABS is doing for you. Because chances are, it'll never engage.
  8. Jan 4, 2010 at 9:16 AM
    PA452
    Western PA
    I promise you, I was not going fast in any circumstance.
    In the case of going through the intersection, I had already almost come to a complete stop. The road was clean and dry, but it was a cold morning. I wish I had a picture of the road where the ABS kicked in to show you. There was not enough ice on the road to have more than one wheel on it at a time. Best I can figure, I was on the brake, still decelerating as I was nearing the stop sign, one wheel hit the patch of ice, ABS sensed it wanting to lock up, and took away braking power to all four wheels. That is a defect, not operator error.
    Same with the situation the other day, except that situation the parking lot was covered in snow. Still, I was crawling, and my traction was good enough to keep myself in control of the truck. I'm assuming ABS felt a wheel hit a slick spot and again decided to just take away my braking power.
    Trust me, it's not operator error.
    ETA: Hypothetically, given a perfectly dry, clean, paved road with a patch of ice one foot by one foot, ABS senses a wheel lock up when it hits that patch of ice, but I have three other wheels on dry pavement with excellent traction, how does it help for the ABS to kick in in that situation?
    That situation was not so hypothetical for me.
  9. Jan 4, 2010 at 9:25 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I am in agreement with Janster. The abs must have detected that you were sliding. ABS does not make your brakes fail. It is only supposed to make the wheels have more traction under panic stop conditions.
    On the other hand, it probably would be good to have an abs over ride switch when on snow and ice.
  10. Jan 4, 2010 at 9:28 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    I hate my ABS too. I've also had it kick in on a hill and caused me to accelerate through an intersection...Also had it kick in several times and not provide any braking assistance.
    I never had a problem with my 99 Taco with no ABS. I'd love to have a button to turn it off around town and anything under 40-45 mph.
  11. Jan 4, 2010 at 9:32 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    x2
  12. Jan 4, 2010 at 9:33 AM
    Bart
    Bart Well-Known Member
    Franklin,NC
    08 TRD OFFROAD V6 4x4
    metra ipod
    I've had this problem but it was my fault and I was playing but I figured I was pressing the brake's to hard if it lock's up use less brake. It's ice you cant drive up a road covered with it what make's you think you can stop on it. It's common since people! If you need to stop on ice get your tires studded.
  13. Jan 4, 2010 at 9:38 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Funny, I credit ABS, in part, for safely making it 300+ miles through the blizzard a couple weeks back. It worked wonderfully for me.
    On ice, forget it, nothing short of studs will help you.
  14. Jan 4, 2010 at 9:43 AM
    PA452
    Western PA
    ABS may have detected one wheel beginning to slide, that I will give you. ABS did not detect the truck sliding, because it wasn't. If one wheel momentarily sliding is reason for ABS to take away the brakes from the other three wheels that still have traction, that is a dangerous defect.
  15. Jan 4, 2010 at 9:45 AM
    #35
    PA452
    Western PA
    If only one wheel is on ice, and the other three are on dry pavement, and I'm moving at a crawl, I guarantee I can stop....unless ABS takes away all my braking power.
  16. Jan 4, 2010 at 9:49 AM
    #36
    OU812
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    --- ABS has one purpose. To enable a given vehicle retain steering control during hard braking conditions. Nothing more.
    Since it was created numeous other systems have been created to further enhance directional stability, braking, traction aids.
  17. Jan 4, 2010 at 9:49 AM
    #37
    Janster
    Jandy
    Lancaster, PA
  18. Jan 4, 2010 at 9:50 AM
    #38
    Bart
    Franklin,NC
    metra ipod
    You might be talking about the EBC then not the ABS.
  19. Jan 4, 2010 at 9:54 AM
    #39
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    A few weeks ago I was driving down a snowy hill and in front of me was an older S10 Blazer from the 80's without abs. He slid sideways down the hill out of control while my Tacoma's abs kicked in and kept me straight and in control. I will agree this system is very sensitive, but I'll keep mine. JMO.
  20. Jan 4, 2010 at 9:55 AM
    #40
    PA452
    Western PA
    I can tell you for 100% certainty in the situation a couple years ago that I wrote about, it did indeed take away braking power from all four wheels, not just the one that momentarily wanted to lock up. It was dry pavement. There was nothing on it, except one patch of ice that couldn't have been more than one foot long front to rear, and only on the right side of the lane. I guarantee three wheels were on dry pavement when the ABS kicked in. And if it only pulsed the wheel that was on ice, I guarantee I would have stopped, instead of coasting through the stop sign.
