ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 12, 2012 at 10:09 AM
    #381
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I see your points, but stopping distance is measured on dry pavement. We are talking about snow and ice in this thread. And in the snow and ice, these ABS set ups faill IMO. I agree with the insurance side of it, thats probably why I would not disable mine. But I sure the hell am aware of how it may act in snow and ice.
    With that said, I have driven in snow and ice, where someone with less experience may have wished they had ABS. And because of my experience in snow and ice, I was able to bring the vehicle I was driving under control. No ABS needed.
    And when you made that comment about someone else in the truck, it sounded as if you where saying it was dangerous to do so, not about insurance. That was where I thought you where wrong.
    And not arguing, just a friendly discussion on TW! :D
  2. Feb 12, 2012 at 10:19 AM
    #382
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    If it was that slick, with locked up wheels you probably would have slid at least another 5 feet.
    I've driven a lot of non-ABS cars, and I rarely get into the ABS on the truck if I'm driving for the conditions.
    I have noticed, on basically glare ice, the truck can take a lot of room to stop. But, I can't say that it wouldn't have taken that much or more without ABS. That same glare ice I've been on with non-ABS vehicles, and the lightest tough of the brakes would lock them up. You're not stopping either way.
  3. Feb 12, 2012 at 10:21 AM
    #383
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Wasn't that slick. I was on slushy snow on pavement. I was just about to stop when ABS thought it was a good idea to kick in, I would have stopped just fine.
  4. Feb 12, 2012 at 10:28 AM
    #384
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bitter much???? :crazy:
    Clearly you don't understand what the word "Nicer" represents.
    I love my Tacoma as well. Doesn't mean that Toyota could have spent a little more time to upgrade certain components....
    I don't know, something like maybe rear disk brakes versus the drums we have....:facepalm: My '91 Isuzu was 4x4 and had 4 wheel disk. What's up with that, that we have drums????
  5. Feb 12, 2012 at 10:32 AM
    #385
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    There is different theories why trucks still use Drum brakes. But as long as properly maintained, there is nothing wrong with drum brakes. They work as they should on the rear end of a truck. Its funny to me that people think drum brakes are somehow "out of date".
  6. Feb 12, 2012 at 10:34 AM
    #386
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Agreed. There's a reason vehicles that need to stop an immense amount of weight still use drum brakes.
  7. Feb 12, 2012 at 10:35 AM
    #387
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I agree completely. Just find it odd is all. :)
  8. Feb 12, 2012 at 10:35 AM
    #388
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I knew we would agree on something! :thumbsup:
  9. Feb 12, 2012 at 11:02 AM
    #389
    Fightnfire
    Marysville, WA
    Agree, let's just stay away from Steeler or Seahawk football. ;)
  10. Feb 12, 2012 at 11:04 AM
    #390
    inouk
    inouk Well-Known Member
    Those kind of conditions aren't a problem with ABS.
    If you where in the mountain area or in an area where temperatures can change very quickly with roads that have snow, hard-packed snow and ice (three togheter), you'll truly understand the limit of the ABS system. I don't drive fast and ABS still kicks-in at stop signs, even at 5mph.
    By shutting ABS off, the stopping distance is much more shorter on snowy-hard-packed-snow-patchs-of-ice. We don't see pavements 5 months/year. I tried many times last week when I disabled ABS and it works. Did you? No? Try it, you'll see. Just try it.
  11. Feb 12, 2012 at 11:06 AM
    #391
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    LOL, as long as your not a Browns or Ravens fan :p, your Ok by me!
  12. Feb 12, 2012 at 12:18 PM
    #392
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just curious, and even though the FJ has the same ABS system we do, why do they have 4 wheel disk, and not us? Factory weight of the 4x4 Access cab is 4045 Lbs. Pretty dang heavy.
    Factory weight of the 4x4 FJ is 4332 lbs (maunal). Heavier......
  13. Feb 12, 2012 at 12:30 PM
    #393
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Had my first experience with the ABS yesterday. Was approaching a green light when it changed at the last minute. With so many red light camera's in the area I tend to stop if possible. My wife gives me crap about this all the time. :rolleyes: But I felt I would stop in time. Well, I sorta did. The ABS imo kicked in and I wound up about half a truck length passed the stop line. I feel if it hadn't been for the ABS I would have stopped in time. It was dry conditions btw. If I had known I would have went as far as I did I wouldn't have bothered trying to stop. Just thought I'd share.
  14. Feb 12, 2012 at 1:22 PM
    #394
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sounds like you were just driving too fast or not paying attention or both .
  15. Feb 12, 2012 at 1:37 PM
    #395
    TacoDawgfan
    Georgia
    Lord forbid anyone ever approach a light and have a split second decision to either stop or go on through. :rolleyes:
  16. Feb 12, 2012 at 1:38 PM
    #396
    OZ-T
    Peter North
    British Columbia
    They don't have yellow lights there ?
    Just goes from green to red ?
  17. Feb 12, 2012 at 1:49 PM
    #397
    TacoDawgfan
    Georgia
    Excuse me for not being clear. I said it changed, I didn't say it changed directly to red. Yes It changed to yellow and by the time I stopped it was red. It was one of those split decisions, stop or go on through. I've known people to get ticketed around here for going through when they claim they couldn't stop in time. So I usually try to stop, at least in Gwinnett county, since they are known for having the red light camera's.
  18. Feb 12, 2012 at 1:51 PM
    #398
    OZ-T
    Peter North
    British Columbia
    Ah so
  19. Feb 12, 2012 at 2:19 PM
    #399
    TacoDawgfan
    Georgia
    Anyway, the point was that I didn't like the feeling that the ABS dictated how I stopped. I felt like I could have stopped in a shorter distance than it allowed. It didn't feel like it was close to the tires breaking loose.
  20. Feb 12, 2012 at 5:01 PM
    #400
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    Then why does the Tundra have disc? or F350 have all disc?
