ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Dec 29, 2014 at 9:04 PM
    #861
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Send her my regards and for FUCKS SAKE do not mention TPMS.
  2. Dec 29, 2014 at 9:16 PM
    #862
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think you looking for a fault, but that ABS does exactly what it supposed do. It's set to work in a truck towing 6500 lb trailer, fully loaded. That's the problem. Usually anything towing that much weight is a full size. Which has different rules because it's not classified as passenger vehicle. Best thing would be to make ABS optional but goverment knows best .:cool:
  3. Dec 29, 2014 at 9:21 PM
    #863
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Function of ABS has nothing to do with weight. Its looking at the rotation of the wheels only. I for one appreciate the purpose of properly functioning
    ABS, and know that in 90%+ cases it will stop you sooner on icy conditions than a driver operator pumping the pedal.
  4. Dec 29, 2014 at 9:25 PM
    #864
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Correct, as the descisions made by the algorithm are only as good as the inputs provided by the hardware, so if that is not working correctly, then there is a resulting problem.
  5. Dec 29, 2014 at 10:19 PM
    #865
    BlueT
    NorthEast
    How ABS function is affected by weight. Software on Prius is different than on Tacoma.
    In fact I never had any problems with ABS when my truck was loaded or towing.
    If you look at horror stories there seems to be none with anybody towing heavy trailer.
    Why is that? You would thin if anything inability to stop would be most preveling for somebody towing trailer.
  6. Dec 29, 2014 at 10:25 PM
    #866
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I think we're on the same page in that weight can influence traction, and braking requirements. I don't understand how it has any influence on what ABS does though.
  7. Dec 29, 2014 at 10:31 PM
    #867
    Crusher69
    Crusher69 Well-Known Member
    Sean
    Denver
    '05 Built
    Abs has safed me from so many accs its not even funy
  8. Dec 29, 2014 at 10:47 PM
    #868
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    did it safe you from accs on snow ?
  9. Dec 29, 2014 at 10:57 PM
    #869
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Can't we all just agree that after 48+ pages & 960+ posts that those things that stop our trucks (most of the time, depending on whether you hate abs or not) are called brakes, not breaks? Unless, of course they break, but in that case, they are broken brakes, not broken breaks...
  10. Dec 29, 2014 at 11:04 PM
    #870
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  11. Dec 29, 2014 at 11:05 PM
    #871
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Drove the Tacoma in snow last week for the first time. ABS was a little wonky to get used to in the parking lots...I need way more practice. Or, just take the Jeep when snow is impending next time...
  12. Dec 29, 2014 at 11:08 PM
    #872
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Nope. Just can't figure out why a five letter word is so hard to get right.
  13. Dec 29, 2014 at 11:10 PM
    #873
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    You nailed it. BFG Rugged Trails, 5k...I should know better.
  14. Dec 29, 2014 at 11:11 PM
    #874
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    'Mericuh skuolls?
  15. Dec 29, 2014 at 11:13 PM
    #875
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    This one time at band camp, my breaks locked up.
    End of story.
    Holy shit, the last 3 pages where funny as shit.
  16. Dec 29, 2014 at 11:14 PM
    #876
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I think there's a few Canadjians doin' the 'break' dance, too...
  17. Dec 29, 2014 at 11:16 PM
    #877
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    We're not understood otherwise, have to try and fit in. :blahblah:
  18. Dec 29, 2014 at 11:19 PM
    #878
    OZ-T
    Peter North
    British Columbia
    downhereicuh
  19. Dec 29, 2014 at 11:20 PM
    #879
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Your understood fine.
    :notsure:
  20. Dec 29, 2014 at 11:21 PM
    #880
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I've been contemplating a set of 265/75 DTs for a while...just want a little more clearance, some real leaf springs, and no vibes in the bargain...
