ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Dec 30, 2014 at 12:52 PM
    #941
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    yeah, just watch F1 / race cars when they go off track and slide on grass. It looks like they actually speed up.
    Stopping in deep snow is easy, just let off the throttle, but that's because there is so much drag/friction on the truck parts that are in the snow.
  2. Dec 30, 2014 at 12:53 PM
    #942
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
    On low traction surfaces , ABS increases stopping distances over threshold braking or ploughing
  3. Dec 30, 2014 at 12:54 PM
    #943
    iitywygms
    iitywygms Well-Known Member
    Norcal
    4x4
    So 2011 and newer Tacomas are better? Or does it start at 2012?
  4. Dec 30, 2014 at 12:54 PM
    #944
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Bingo.
  5. Dec 30, 2014 at 12:56 PM
    #945
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    umm, i understand ABS is performing threshold braking, at a much faster rate than a human could. Perhaps our system releases too much brake pressure, and does not operate close enough to the threshold. :notsure:
  6. Dec 30, 2014 at 12:59 PM
    #946
    OZ-T
    Peter North
    British Columbia
    If you don't believe me , google " does ABS increase stopping distances on snow " and pick one of the 1000 responses , that way I won't be accused of picking one that supports my position while ignoring others
  7. Dec 30, 2014 at 1:03 PM
    #947
    OZ-T
    Peter North
    British Columbia
    Threshold braking done manually , allows you to introduce a period of ploughing into the equation , ABS automatically releases brake pressure at the first signs of ploughing ( slipping ) , so you don't get the advantage of it
    EDIT : maybe calling it threshold braking is technically a misnomer , I'm referring to old school pre-ABS on snow braking , you dig ?
  8. Dec 30, 2014 at 1:04 PM
    #948
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    :laugh: fair enough. To make my opinion clear I prefer ABS versus no ABS. I do like to have the option though, as most modern vehicles do, that ABS stops functioning at speeds less than say 10 or 15km/hr, and an e.brake I can modulate easily :D
  9. Dec 30, 2014 at 1:04 PM
    #949
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    This.
    So with out ABS there would be no story here.
  10. Dec 30, 2014 at 1:08 PM
    #950
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If I'm driving 1 mph on ice and apply the brakes I want the wheels to stop... every time.
  11. Dec 30, 2014 at 1:14 PM
    #951
    tjjmon
    tjjmon Well-Known Member
    Billings, Montana
    2015 DCSB Pyrite Mica 4x4 TRD OR
    Weathertech
    I have a 2000 4Runner and a 2015 Tacoma that just turned 1,000 miles. The ABS on the 4Runner works great. Never had a scary moment with it. Takes alot of pedal pressure to make it work. On the other hand, the Tacoma is way too sensitive. It has scared the crap outta me a couple of times. Barely rolling up to an icy intersection, hit the brakes, and slide on through. The 4Runner never does that. I've been driving these crappy roads for more than 30 years so I feel I know what I'm doing. The ABS is way too sensitive on my truck. I would take the 4Runner's ABS any day over the Tacoma's up here in icy Montana. They did it right back in 2000, why not now?
  12. Dec 30, 2014 at 1:17 PM
    #952
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    Did you ever think that maybe you went from a part of the road that had good traction to a part of the road that didn't and that is why ABS kicked in? If you are going down a slight snow packed incline where it kicked in it is probably the same part of the road that others started to slide and slicked/shined up that part of the packed snow. Sounds like it worked exactly how it was supposed to. Didn't lock up while you had good traction then hits a slick spot and it allows to you steer rather than sliding around and backing in to traffic.
    The only way to tell if an ABS system is inferior to your non-ABS driving skill is to see how far it took to stop with the ABS on then try a few stops without ABS. No one is good enough to tell what the tire is doing exactly to know whether or not the ABS needed to kick in. If it did it is because there was too much braking on the tire and it over came its friction abilities such as this situation. Chances are on slick packed snow you wouldn't have stopped any faster without ABS.
    Tyler
  13. Dec 30, 2014 at 1:57 PM
    #953
    TacomaRobert
    TacomaRobert Well-Known Member
    Sounds good. Everyone should agree with that. There is some speed where ABS should end.
  14. Dec 30, 2014 at 1:59 PM
    #954
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    99 4runner and 13 taco here
    agreed. 4runner abs won't kick in until you are on it hard, but it does kick in
    VSC and stability control is far more complex to sort out and decide 'where is the strength in the system going to be ?' I think it is highway speed 'moose maneuver' is the primary function...straight line braking on ice or water was secondary. VSC did save my ass at 50mph in snow where I was going sideways on interstate... and I have front/rear dashcam video proof of that
  15. Dec 30, 2014 at 2:05 PM
    #955
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    soooo...are you saying don't drive too fast for conditions?
  16. Dec 30, 2014 at 2:10 PM
    #956
    Idaholandho
    *putting on duck suit to go throw bread at people and quote Biblical nonsense....
  17. Dec 30, 2014 at 2:11 PM
    #957
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    ^^^Winner winner chicken dinner.
    I've never had a scary moment with mine and I have driven in some pretty bad shit. Maybe I am lucky or maybe I just understand how ABS works and drive accordingly or maybe the pre- '11 dont have this issue.. :notsure:
  18. Dec 30, 2014 at 2:13 PM
    #958
    scocar
    scocar Patron of the Farts
    ABS = Always Broad Siding.
    edit: in for the duck suit.
  19. Dec 30, 2014 at 2:17 PM
    #959
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    ABS = Avoiding Bad Slides
    Edit: Of course you are.
  20. Dec 30, 2014 at 2:20 PM
    #960
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    So do I in 97% of panic situations. But in that other 3%, when I know what I would like to have happen and can't make it happen because the vehicle has other ideas, then not so much.
