ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Jan 6, 2015 at 4:07 PM
    #1041
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    STOP STALKING ME AROUND THE SITE ITS GETTING OLD
  2. Jan 6, 2015 at 4:17 PM
    #1042
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Just to be clear, it was a Honda Civic that went into the snow bank, and the Tacoma following behind her had no problems stopping in time, and did not engage ABS. So maybe there is an ABS out there that is worse than Tacoma? :notsure:
    edit: I'm just going out on a limb here, but maybe, just maybe, the Tacoma ABS did not engage because there was NO low traction situation encountered, considering proper winter tires, driven at a speed matching the conditions, and no panic braking required on the part of the Tacoma.
  3. Jan 6, 2015 at 4:20 PM
    #1043
    OZ-T
    Peter North
    British Columbia
    YOU SAID IT WASNT ABS
    BUNCH OF HIPPYCRATES
  4. Jan 6, 2015 at 4:25 PM
    #1044
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Speculation on my part to acknowledge there just might be other factors/variables at work. You know, like keeping an open mind, then looking at the facts, observations to see if it supports the hypothesis. Scientific stuff.
    I'm a Hippycrate in disguise, my long hair is gone.
  5. Jan 6, 2015 at 4:26 PM
    #1045
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
  6. Jan 6, 2015 at 4:27 PM
    #1046
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    from the land of OZ?
  7. Jan 6, 2015 at 4:30 PM
    #1047
    OZ-T
    Peter North
    British Columbia
    /thread
  8. Jan 6, 2015 at 4:31 PM
    #1048
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Touche, now back to our regular programming - ABS, Stories of Wheels turning, and not stopping. :eek:
  9. Jan 6, 2015 at 4:31 PM
    #1049
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Speaking of abs and midgets, I know damn well somewhere down the line there was a hippy involved in Entune's product development.
  10. Jan 6, 2015 at 4:34 PM
    #1050
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    and was likely stoned at the time. Explains the long boot-up time, and inability to respond to more than one stimuli at a time.
  11. Jan 7, 2015 at 5:22 AM
    #1051
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Duuuuuuude.
  12. Jan 7, 2015 at 6:55 AM
    #1052
    TacomaRobert
    TacomaRobert Well-Known Member
    Ok, let's take a new turn.
    Have you ever read the threads on this forum where ABS screws up stopping for people off roading on sand? These people disconnected it and their stopping distance was extremely improved.
    I would encourage you (and the others here who think that the ABS Pucker can ONLY be driver error) to find and read those threads. They might give you a new perspective? Or maybe not.
  13. Jan 7, 2015 at 7:22 AM
    #1053
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Good, glad to hear! Why are you still here? :confused: Seriously. The thread title doesn't say that the ABS on YOUR truck is dangerous, it says the ABS on THIS truck is dangerous. Which clearly doesn't apply to your truck. Not much more to say about that, is there?
    Like NASCAR! ;)
  14. Jan 7, 2015 at 7:32 AM
    #1054
    TacomaRobert
    Hey OZ. You reading?
    You seem knowledgeable. I think you may have mentioned already, but have you disconnected ABS? Might there be a way to make it disconnect only below 10 mph?
  15. Jan 7, 2015 at 8:17 AM
    #1055
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Funny thing is people who state that their ABS worked would have stopped their truck in shorter distance than with ABS.
    The only reason why ABS has shorter stopping distance on Dry pavement is because on dry pavement when your wheels lock up, rubber contacting surface is starting to turn to liquid (Ever seen skid marks) So in that one instance ABS gets shorter distance.
    In any other case ABS gets longer distance because every extra turn tire can make its a loss.
    The benefit of ABS is that people don't have to pay attention how they drive. If you pay attention to the road, in emergency situation you will be using brakes properly lock when you need, release when you need to steer.
    Maybe that's whats needs to change.
    Make ABS to disengage when wheels are straight, engage when wheels turn (left/right). That way when you slamming on brakes to stop you lock up, when in straight line. Make adjustment for G force. With high G force means you are on pavement so let ABS engage than with lower G force means you are not on dry pavement and let option 2 (engage when wheels are turned, disengage when straight)
    This can be done on our trucks all it needs to happen is software update with new algorithm.
  16. Jan 7, 2015 at 8:28 AM
    #1056
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    I'm still trying to make sense out of this.
    Are there instances where it would be nice to be able to turn ABS off? Yes, absolutely. Would it be nice of Toyota to just put this option in? You bet.
    But until that happens you are either stuck with ABS and can continue to bitch about it or you can deal with it and learn how to drive with it the way it is or you can come up with a mod that either turns it off full time or better yet, turn it off at will. Which I believe some people have.
    Your right, the title of the thread doesn't say anything about "Robs '09 ABS sucks", but I do have a Tacoma which puts "my" truck in this catagory.
    From what I have gleaned out of this thread, it's a bunch of guys bitching back and forth about the pro's and cons of ABS vs. no ABS. Or rather just bitching about ABS. So as to the "why am I here?" portion of your post, I was merely giving the non-bitching side of the coins opinion.
    As far as the guys running in sand, I am sure there are a ton of special circumstances out there that are not the "norm" for alot of people. I personally don't typically travel in sand or dunes so this is of no concern to me. The off chance that I do get on a dune, I am more than confident in my driving ability that I could handle it with ABS, just like I am on snow and ice.
    Have I met your question as to why I am here (seriously) with a reasonable response? Do I have your permission to stay? Maybe you should quarry the OP to change the title of the thread to "ABS sucks on this truck, if you like it, stay the fuck out", until that happens I guess I can go where ever I want.
    :rolleyes:
  17. Jan 7, 2015 at 8:33 AM
    #1057
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    ^ I like this guy
  18. Jan 7, 2015 at 8:36 AM
    #1058
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :mad: I just want ABS on my office chair, is that so much to ask?
  19. Jan 7, 2015 at 8:36 AM
    #1059
    BlueT
    NorthEast
    Your truck is TRD Offroad Right ?
    That means your system is different, and it will either have no problems or have issue in much lesser form, because systems on TRD OR have extra connection return brake fluid from the ABS pump, hence when ABS kicks in it can provide pressure to one wheel and let pressure out from other wheel in the front or the back at the same time because one line can move fluid in one direction and other line in opposite direction.
    vs
    ABS on non-TRD OR trucks where front and rear have supply line that is shared by both wheels.
    Apples and Oranges
  20. Jan 7, 2015 at 8:37 AM
    #1060
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    quickly trigger your emotions on and off, steer away from the dark side, and whew, everything will be ok.
