ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Jan 21, 2015 at 1:35 PM
    #1181
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Sorry, no time to play.
  2. Jan 21, 2015 at 2:12 PM
    #1182
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Me neither
  3. Jan 21, 2015 at 2:15 PM
    #1183
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
  4. Jan 21, 2015 at 4:28 PM
    #1184
    xsteinbachx
    xsteinbachx Well-Known Member
    Victoria, BC
    2017 White TRD Sport DCLB 4x4
    Or the far superior manual compared to the 0.05 second shifting automatic in F1.
  5. Jan 21, 2015 at 4:43 PM
    #1185
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    This has already been solved. Everyone without ABS uses a wizard to enchant there wheels not to skid :rolleyes: jks.
    Turn off your ABS if you hate it. Mines works just fine and I've never felt like it's put me in an out of control situation.
  6. Jan 21, 2015 at 4:51 PM
    #1186
    OZ-T
    Peter North
    British Columbia
    Semi-automatic
    "The gearboxes of modern Formula One cars are now highly automated with drivers selecting gears ‘seamlessly’ via paddles fitted behind the steering wheel. The 'sequential' gearboxes used are very similar in principle to those of motorbikes, allowing gear changes to be made far faster than with the traditional ‘H’ gate selector, with the gearbox selectors operated electrically. Despite such high levels of technology, fully automatic transmission systems, and gearbox-related wizardry such as launch control, are illegal - a measure designed to keep costs down and place more emphasis on driver skill. Transmissions - which must have eight forward gears, the ratios having been chosen before the season - bolt directly to the back of the engine"
    http://www.formula1.com/inside_f1/understanding_f1_racing/5280.html
  7. Jan 21, 2015 at 4:52 PM
    #1187
    OZ-T
    Peter North
    British Columbia
    ABS used to be legal in F1
  8. Jan 21, 2015 at 5:00 PM
    #1188
    OZ-T
    Peter North
    British Columbia
    I think any one of them would opt for whatever set up makes them go around the circuit the quickest
    F1 tends not to race on snow covered tracks though
  9. Jan 21, 2015 at 5:00 PM
    #1189
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Only if they are allowed to use the programming from a late 2000's Tacoma. Oh, and only if they can use the Tacoma's rear disc brakes on every wheel. :p
  10. Jan 21, 2015 at 5:03 PM
    #1190
    OZ-T
    Peter North
    British Columbia
    Carbon fibre brakes
  11. Jan 21, 2015 at 5:13 PM
    #1191
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :wink:
  12. Jan 21, 2015 at 5:16 PM
    #1192
    OZ-T
    Peter North
    British Columbia
    No
  13. Jan 21, 2015 at 5:18 PM
    #1193
    OZ-T
    Peter North
    British Columbia
    Same answer minus the no snow comment
  14. Jan 22, 2015 at 12:00 PM
    #1194
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    The stock pads work great under harsh circumstances, but they're actually a bit "slick" for my taste, even on a dry level road.
    They last like iron though. After 45,000 (light duty) miles mine were still 80% there; but IMO they're probably the worst type of pads for a light ABS truck on ice/snow. I believe that by the time the ceramics actually bite they do it too hard, and the ABS thinks the wheel's skidding and releases pressure; thus no brakes on ice.
    I haven't really kept up with this issue, but I'm wondering if any of you have tried replacing the stock ceramic pads with organics or something with a softer initial bite?
  15. Jan 29, 2015 at 4:42 AM
    #1195
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Until today I wasn't really ready to truly believe the people saying the abs sucks. I've never experienced any problems with it myself...UNTIL THIS MORNING.
    I was parked and in the 7-11 before going to work and when I came out a woman was standing next to my truck. I can see the front is bashed (I backed into the space) and she tells me she backed out of her space, hit the brakes and the truck just kept going. Sure enough, she was in a trd tacoma, older than mine but still 2nd gen.
    Either she was lying and never hit the brakes or her abs kicked in (snow covered parking lot) and didn't let her stop. Either way, sucks to be me.
  16. Jan 29, 2015 at 4:55 AM
    #1196
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    That sucks.
    My ABS doesn't kick in at all in reverse. If I didn't have time to shovel my driveway before I leave to somewhere. (it's a slight grade to the street ) I slide right out of it if keep the brakes on. Got to old school pump brake to I hit clean street.
  17. Jan 29, 2015 at 6:04 AM
    #1197
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You know all you have to do is lift your right foot if the ABS kicks in it kind of like using your foot on the brake when there was no ABS.
  18. Jan 29, 2015 at 10:14 AM
    #1198
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    First week of owning my 2010 prerunner, 30,000 miles on it, the abs kicked on nearly sending me into a busy intersection. Dry road, no reason for it kicking in, hasn't happened again 40,000 miles now. Seriously pondering the kill switch, scary as f**k. Zero accidents over the last 20 years, would like to keep it that way.
  19. Jan 29, 2015 at 11:42 AM
    #1199
    scocar
    scocar Patron of the Farts
    retroLOL
  20. Jan 29, 2015 at 1:51 PM
    #1200
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    She was lying. Only way I remotely seeing this happening is if there was ice, if not, she just straight up smacked you!
    Either way sucks for you bro.
