ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 5, 2015 at 11:17 AM
    #1401
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    :thumbsup:
  2. Feb 5, 2015 at 11:25 AM
    #1402
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    That sounds great to me
  3. Feb 5, 2015 at 11:25 AM
    #1403
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    99.999 percent of the time there is zero issue with the concept of ABS but if the conditions are just right (gravity and/or momentum and yes actually s-p-e-e-d involved) you may eventually learn a very hard lesson. I wonder about some accidents that involve Highway Coaches (buses) sliding on ice into stopped 18 wheelers but it's just a theory. [​IMG]I know.. Carry on.
  4. Feb 5, 2015 at 11:28 AM
    #1404
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    aaaaaand Bingo was his Name - O
  5. Feb 5, 2015 at 11:29 AM
    #1405
    Konvict KROG
    Louisiana
    My parent's went back to college awhile back. They drove a campus bus for awhile and they did not have ABS in the winter. I don't know if it is legal or anything else, but it was something they had done because of the buses sliding around in the snow in the Midwest and a few minor accidents.
  6. Feb 5, 2015 at 11:38 AM
    #1406
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    ^ This
  7. Feb 5, 2015 at 11:39 AM
    #1407
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ Maybe over 50 mph would work.
  8. Feb 5, 2015 at 11:44 AM
    #1408
    OZ-T
    Peter North
    British Columbia
    Or 30mph , which is the speed limit that Toyota somehow came up with for the VSC system switching on and off with one push of the VSC button in our rigs
  9. Feb 5, 2015 at 11:49 AM
    #1409
    Konvict KROG
    Louisiana
    stupid VSC fucks with my dohnuts.. just saying lol
  10. Feb 5, 2015 at 11:53 AM
    #1410
    OZ-T
    Peter North
    British Columbia
    You're not turning it " off " correctly then
  11. Feb 5, 2015 at 11:53 AM
    #1411
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Too much computer control. Next is the car that drives itself. What could possibly go wrong there?
  12. Feb 5, 2015 at 11:53 AM
    #1412
    OZ-T
    Peter North
    British Columbia
    That's already here
  13. Feb 5, 2015 at 11:56 AM
    #1413
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Oh, God I can just imagine the Pimpmobiles. [​IMG]
  14. Feb 5, 2015 at 11:58 AM
    #1414
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Don't have ABS on my 2002. I see a lot oe 2008-10s having problems. Anyone expierencing this problem on 2015 or is it all years depending of the road conditions and speed????
  15. Feb 5, 2015 at 12:02 PM
    #1415
    Konvict KROG
    Louisiana
    No the is for the spur of the moment type.
    It works just fine when I plan ahead and touch the button.
  16. Feb 5, 2015 at 12:04 PM
    #1416
    Konvict KROG
    Louisiana
    Best I can say is probably.
    2005-09 should be the same
    and 09-15 should be the same.
    Although im just assuming they also changed something in the ABS when they changed the traction control. The ABS could be identical for all I know
  17. Feb 5, 2015 at 12:08 PM
    #1417
    Shelf Life
    Rob
    Central Oregon
    Yes, I mean on a wide scale. I wonder how two motorists would sort out an accident if their driverless cars collided? :)
  18. Feb 5, 2015 at 12:19 PM
    #1418
    Konvict KROG
    Louisiana
    Same way. Finger pointing, and clueless investigations both over-ruled by a one solution for all answer.
    Car in back, at fault.
    Car hit in side, not at fault.
    Everybody sue Toyota for failing. Defend and bail out GM.
  19. Feb 5, 2015 at 12:22 PM
    #1419
    OZ-T
    Peter North
    British Columbia
    So 09's are the same as both ?
  20. Feb 5, 2015 at 12:22 PM
    #1420
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    Yes it can happen in a 2015.
