ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 10, 2015 at 12:18 PM
    #1481
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I guess you missed this:
    What does a dealer or two say about it? Have you had it in for service, or are you just ranting?
  2. Feb 10, 2015 at 12:19 PM
    #1482
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Feb 10, 2015 at 12:40 PM
    #1483
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Well I have idea why dont you let your wife drive your Tacoma?
    Or better yet show us how you can steer around traffic with no brakes on busy intersection after your blow red light. Drain brake fluid hit intersection and show us how you steer around cross traffic. :rolleyes:
  4. Feb 10, 2015 at 1:01 PM
    #1484
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Actually when I had my ABS issue a couple times; I couldn't even steer the truck to make any kind of turn, it would only go straight. It's literally like you are floating on top of the surface of the road in slow motion when it happens.
  5. Feb 10, 2015 at 1:16 PM
    #1485
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    To clarify, are you saying that when you turned the wheel, the truck would not turn, OR that you were unable to move the steering wheel?
  6. Feb 10, 2015 at 1:24 PM
    #1486
    Snowbrdr1220
    PA
    The ABS issue has happened to me twice on the road, and once I didn't try to turn because of oncoming cars. The other time I did try to turn, and was able to turn the wheel, but the truck would keep going straight while the ABS was going off, as if I was just floating on top of the surface of the road no traction at all while ABS was hammering away.
    Also, both times when this happened to me the ABS kicked on and would never kick off until the truck finally came to a complete stop, even if you left off the brake for a second and then went back on the brake it was instantly still in ABS mode with not even a second of delay before it started back up. I've never experienced anything even close to that in any of the other ABS vehicles I've owned.
  7. Feb 10, 2015 at 1:49 PM
    #1487
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    Although I have not experienced any unusual ABS actions, I will say this thread his made me more aware of potential problems with the ABS in adverse weather and likely increased my caution when driving in such conditions.
    Thank you to all contributors!
  8. Feb 10, 2015 at 1:59 PM
    #1488
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Again, this seems like a tire issue. A tire that is "floating" should be free wheeling and able to steer. If it's not it's a problem with the road contact patch. Again, I'm not saying that snow tyres will fix your ABS problem, but it's the only thing you can change easily right now to allow you to deal with the situation better and hopefully gain a little bit of braking back while at least allowing you to steer.
    Otherwise you disable your ABS and VSC. If that doesn't bug you have at her.
    She does drive my Tacoma, lots, soo..... :notsure:
    I'd rather enter that intersection with no brakes and the ability to steer than neither. That's what I was trying to say. What happens if you have the green and another guy blows the red? Neither ABS or good ole' BlueT's threshold braking mastery is going to stop you in the 50-100 ms you have before impact. However that flinch reaction reaction of hitting the brakes (and deploying ABS) combined with the ability to turn the collision from a 90 degree impact to a 45 degree impact dramatically reduces the chances anyone is going to die. Period.
    We could go for days in this circle lol.
  9. Feb 10, 2015 at 2:19 PM
    #1489
    Snowbrdr1220
    PA
    I can tell you right now it's not a tire issue, I don't care what it "seems" like to you. Until you have experienced it for yourself, you will have no idea what we are talking about. Am I going to change my tires in the near future, yes. Do I think a tire with better traction will help, yes. Is this issue completely related to tires, hell no!
    I'm certainly going to install the disable ABS switch also, so that I can flip it in the middle of the ABS issue happening when/if it happens again in the future.
  10. Feb 10, 2015 at 2:32 PM
    #1490
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Will 285's have an effect on the ABS on this trucks?
  11. Feb 10, 2015 at 2:37 PM
    #1491
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Your Tacoma is made in Texas. How do you expect them to know anything about stopping on snow or ice, with crappy tires, and an uncalibrated VSC?
  12. Feb 10, 2015 at 2:43 PM
    #1492
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. The friction coefficient changes in proportion to the operation angle of the treadle valve actuation dampers motor inertia springs.
  13. Feb 10, 2015 at 2:45 PM
    #1493
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I never said that the issue is 100 percent your tyres. For the last time, I said Winter tyres will allow you to steer if your tyres are rotating at the same speed as the pavement, which is better than no braking and no steering for most people. Hell, maybe with better tires you'll even stop a bit faster which would help wouldn't it? Take some pills :thumbsup:.
  14. Feb 10, 2015 at 2:48 PM
    #1494
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
  15. Feb 10, 2015 at 2:49 PM
    #1495
    OZ-T
    Peter North
    British Columbia
    You said to smack the shit outta you
  16. Feb 10, 2015 at 2:51 PM
    #1496
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    So, I'd need to recalibrate the PSI threshold on the treadle valve or the inertia springs? How many degrees variance is within OEM specs on the operation angle, do I need to calculate the atmospheric density at 0*c vs. compression ratio at 32*f?
  17. Feb 10, 2015 at 2:55 PM
    #1497
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The inertia springs are coil, so no PSI adjustment required. You have to re calculate the rotational mass added to the un sprung mass of the vehicle, then add the correct amount of corresponding frictional surface area to the vehicles retarding devices.
  18. Feb 10, 2015 at 3:26 PM
    #1498
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I would divide the sum of the masses by the product of frictional area and the coefficient of friction. That way, using the ratio of frictional surface radius to frictional area radius the inertia could be modulated at a rate proportional to the angular velocity.
  19. Feb 10, 2015 at 3:34 PM
    #1499
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So, there is a possibility TW members could send a man to Mars. Tacoma World Interstellar Technology Systems. ;)
  20. Feb 10, 2015 at 3:54 PM
    #1500
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Where do you think we send banned members?
