ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 10, 2015 at 3:57 PM
    #1501
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Troof
  2. Feb 10, 2015 at 4:08 PM
    #1502
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    In that case how do I get banned? Iwanna go to mars!
  3. Feb 10, 2015 at 4:09 PM
    #1503
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its not a pleasant trip.
  4. Feb 10, 2015 at 4:09 PM
    #1504
    nagorb
    Alabama
    2001 dbl cab 4x4
    But mars man!
  5. Feb 10, 2015 at 5:50 PM
    #1505
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Whenever you install tires (or anything for that matter) that far outside the engineering criteria of any vehicle there can be unintended consequences. Our IFS trucks just weren't designed to accept 3" lifts, 33" and taller tires, or tires over 10.5" wide. Sometimes it works fine and sometimes you get vibes, rubbing, alignment issues, and strange behavior with the computer controlled systems like ABS. Caveat emptor.
  6. Feb 10, 2015 at 5:56 PM
    #1506
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Because of payload cost restrictions, you get sent one matchbox sized chunk at a time. The whole process could take years.
  7. Feb 10, 2015 at 6:11 PM
    #1507
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    I think the best way to describe the ABS is inconsistent and unpredictable. I've owned this truck for 7 months and had the no stop issue happen 2 times. The last time this happened I was commuting in stop and go traffic for close to 2 hours going around 5-10 MPH. I applied the brakes hundreds of times that morning and only had the one instance where the truck wouldn't stop (coasting or floating along as others have said). Today was another snowy day and I tried to get the truck to recreate this issue and couldn't by using 2H, 4H, slamming the brakes, lightly applying the brakes, etc. Most of the times the tires would actually lock up like I didn't have ABS at all. Its very strange. For all of those that say its just the tires, trust me its not the issue. Obviously better tires will grip better and not require the ABS system to activate but its still the same ABS system which will eventually have an issue again it will just be less frequent.
  8. Feb 10, 2015 at 8:39 PM
    #1508
    nagorb
    Alabama
    2001 dbl cab 4x4
    In that case for me decades! I still want in
  9. Feb 11, 2015 at 7:42 AM
    #1509
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Hmm, sounds familiar! I should add that I've tried to reproduce the issue on a couple different occasions also, but haven't been able to either. Last time it happened to me on the road; I went back out within a couple hours in pretty much the same conditions and just couldn't get it to happen. Truck stopped right away every time at the same low speeds and on various snowy surfaces.
  10. Feb 11, 2015 at 8:19 AM
    #1510
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
  11. Feb 11, 2015 at 9:59 AM
    #1511
    Mikelu
    Mikelu Well-Known Member
    Cupertino, CA
    14 Tacoma 4x4 TRD
    Yes, ABS is supposed to modulate the brakes, but in two instances they released the pressure on my brakes (2005 Tacoma): 1) The brake pedal went to the floor and the brakes released when I was rock crawling; 2) During a panic stop, the brakes released when the speed went down to about 15 mph, causing the vehicle to smash into the vehicle in front of me. On #1, modulation would not have helped. Would it in #2? I don't know.
  12. Feb 11, 2015 at 10:07 AM
    #1512
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I agree one hundred percent with disabling ABS during Off Roading. Computer controlled safety features design for pavement aren't a good idea when off road for sure. As for #2, if the brakes are releasing totally then that's not just an ABS problem, that's something they need to recall. No matter why brakes are releasing, whether it's cause by the ABS computer or something else, it needs to get fixed if it's happening.
  13. Feb 11, 2015 at 10:15 AM
    #1513
    Mikelu
    Cupertino, CA
    14 Tacoma 4x4 TRD
    I had it serviced after the rock crawling incident and the snow-sliding incidents described by others. The dealership could find no problems. I asked them to check out my 2014. Again, they found no problems, which may be correct as I have not experienced any problems yet. I haven't been in the snow this year and I locked my rear differential (disabling ABS) on my September off-road trip.
  14. Feb 11, 2015 at 10:21 AM
    #1514
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I meant it should be recalled and fixed. Not just looked over by a dealer.
  15. Feb 11, 2015 at 10:40 AM
    #1515
    Mikelu
    Cupertino, CA
    14 Tacoma 4x4 TRD
    AMEN!
  16. Feb 11, 2015 at 9:18 PM
    #1516
    BamaToy1997
    Bill
    Navarre, FL
    I have been doing some extensive research and thinking on the Tacoma ABS system. I have also done more research on the firmware and how it operates. That thinking has come up with some VERY interesting and important thoughts. Now I am not about to go into searching every post in this thread, but I am sure I can get a lot of feedback to help out here from those who have had an issue.
    Here is the school of thought:
    1. The ABS system is calibrated for factory sized tires/wheels.
    2. The ABS sensors are measuring wheel speed at the hub itself.
    3. When the truck is physically moving forward at say 45MPH, the ABS sensor also says 45MPH
    4. With oversized tires of say 33 inches tall, the truck would be physically moving forward at 45 MPH, but the ABS sensors would be reading approximately 13% slower (the larger the tire, the slower the hub spins over the same distance. 13% is the approx difference between a stock tire and a 33 inch tire)
    5. So as you are braking, the change in rotational speed from what the ABS computer PERCEIVES is the speed, versus what the ACTUAL change in speed, COULD trigger the ABS computer into thinking that the wheels were about to lock up.
    Again, this isn't an excuse for all of this, but it is just a bit of thought I have been considering. Part of this thought is also derived from when I was working at GM. When a customer had a Silverado truck and they installed larger tires, GM had a way to compensate for the change in tire size. The technician would use the scan tool to go into the computer and tell the computer what size tires were on the truck. Interestingly enough the computer that this information was entered into was the ABS computer. The service manual also states "Incorrectly entering the tire size may cause erratic operation of the ABS system."
    Thoughts?
  17. Feb 11, 2015 at 9:24 PM
    #1517
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do the same ABS tire size parameters exist when using a scan tool with the Tacoma ?
  18. Feb 11, 2015 at 9:28 PM
    #1518
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    The poll I put together seemed to rule tire size out as ABS issues were reported almost equally across vehicles with stock size tires and over sized tires. I thought I was on to something too.. I still think it might have something to do with it.
  19. Feb 12, 2015 at 6:52 AM
    #1519
    Snowbrdr1220
    PA
    Also, most of the people who have had this issue, including myself, don't have it all the time. It's happened to me only a couple times over three winters, and I'm not even able to reproduce it at all on a 100% stock truck.
    If the issue was really related to larger tires and not recalibrating the system, then it would happen all the time and would be much easier to replicate. Same thing if bad tires were the main cause too.
  20. Feb 12, 2015 at 7:21 AM
    #1520
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    ABS should not be concerned with an absolute value of speed, rather the relative change in speed from rotating to zero as compared to other wheels.
