ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 12, 2015 at 8:08 AM
    #1521
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yeah except to be recalled it has to be seemed by NHTSA a safety issue. The same organization says that ABS will extend your breaking distance in bad condition so in essence what we getting is "Normal" for ABS.
    Yeah we been down that road. It happens on stock tires, it happens on aftermarket.
    If it was related to tire size people would get that issue more often.
    I dotn think anybody will be able to solve this in 100% with out looking into the ABS logic and changing it.
    I understand how the problem is happening but not much can be done by us. Toyota has to fix this, and they won't unless there is another class action suit hanging over them.
  2. Feb 12, 2015 at 8:18 AM
    #1522
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    This might be a stupid question, but here it goes...
    Probably close to 3 years ago, my ABS module crapped on me and hasn't been working since. And I actually like it that way, because like many of you, I think it's crap. Question is, since I'm not even using the unit, can I completely take it out of the engine bay? I want to put a second battery under the hood and it looks like that would be a good place to put it. At the very least, I'll probably move it like this guy did:
  3. Feb 12, 2015 at 11:12 AM
    #1523
    BlueT
    NorthEast
    You could remove it but:
    1 You need to get replacement splitter so the front line powers front brakes and rear line powers rear brakes.
    2. You would need to get proportioning valve for rear wheels.
  4. Feb 12, 2015 at 12:26 PM
    #1524
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    If a similar problem is reported by enough people then the NHTSA will investigate it thoroughly. Better to try to get everyone who is having issues to report it and hope they demand a fix to it than be cynical and do nothing at all.
  5. Feb 12, 2015 at 6:34 PM
    #1525
    BamaToy1997
    Bill
    Navarre, FL
    See, I don't think that would be 100% true. Even a slight variation can cause a parameter to fall within the requirements for ABS activation. Just a thought I was having mind you. Something to think about.
    That is my point. With a larger tire, you DO have a different change in rotational speed when braking. thus the thought that it COULD possibly contribute to a problem.
  6. Feb 12, 2015 at 8:29 PM
    #1526
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the Brake Pedal went to the floor that isn't the ABS. Air in the line, Brake Master cylinder etc...
  7. Feb 12, 2015 at 8:31 PM
    #1527
    MJonaGS32
    MJ
    SF Bay Area (East)
    Mehhh. I'll just move the abs module like the picture lol
  8. Feb 13, 2015 at 8:35 AM
    #1528
    Mikelu
    Mikelu Well-Known Member
    Cupertino, CA
    14 Tacoma 4x4 TRD
    Nope, it was the ABS. It only happened the two times. Try taking your '05 off road, have one or two wheels off the ground and press on the brake. The pedal will go to the ground with absolutely no braking!
  9. Feb 13, 2015 at 9:09 AM
    #1529
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    This seems to be the heart of the matter.
    I doubt if the design (not reality) was ever intended to relieve all of the pressure.
    I mostly off-road in PA, which is rarely flat, and have often had one or two wheels off the ground while descending.
    If this were to happen more often, with the number of Tacos, and the hours of wheeling, there would be a lot more stories.
    I am wondering if this is a vehicle specific problem with intermittent mechanical problems that the system is not able to compensate for.
  10. Feb 13, 2015 at 9:15 AM
    #1530
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My last ABS engagement behaved this way too , the pedal slowly went all the way to the floor while I held constant pressure on it , ABS pulse happening the entire time , then it slowly started pushing back against my foot and started returning back up
  11. Feb 13, 2015 at 9:18 AM
    #1531
    Mikelu
    Cupertino, CA
    14 Tacoma 4x4 TRD
    I filed my complaint on March 13, 2014. The Vehicle Safety Hotline is (888)327-4236. Your complaint may be filed by going to https://www-odi.nhtsa.dot.gov/ivoq/
    I asked if they would like to examine the vehicle, but they declined. Currently, there are no open investigations for the 2005 Tacoma (http://www-odi.nhtsa.dot.gov/owners...ia.make=TOYOTA&searchCriteria.prod_ids=216309) Only 2 complaints are reported for 'SERVICE BRAKES' problems, but there are 86 complaints for 'VEHICLE SPEED CONTROL' problems. I don't think they will open an investigation with only 2 reports (they did on the 86 complaints, I believe).
  12. Feb 13, 2015 at 9:52 AM
    #1532
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    I wonder if the issue could be with the ABS simply not shutting off when traction is regained. Like ABS should be kicking off after a few seconds but isn't.
    Both times it's happened to me the ABS would not shut off while on the brake for a very long time and at very slow speed. When I let of the brake completely for a second ABS stopped. Then as soon as I lightly touched the brake, ABS was instantly in full force just barely touching the brake pedal again, hardly enough to actually even brake the truck.
  13. Feb 13, 2015 at 10:39 AM
    #1533
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    The fact they told you only 2 cases were open pretty much tells us that no one from here is reporting there problem, even though they consider it enough of an issue to cut some wires and disable the system...
  14. Feb 15, 2015 at 11:35 AM
    #1534
    Mikelu
    Cupertino, CA
    14 Tacoma 4x4 TRD
    Actually for the 2005 Tacoma, there were only 2 reports against 'SERVICE BRAKES'. I looked again and found many more under 'SERVICE BRAKES (HYDRAULIC)". I could find nothing listing 'ABS'. Suspecting the problem is related to 2005-2009 Tacoma, I started looking at other years. The 'pedal to the floor' complaint came up quite a bit on the 2006 Tacoma under the hydraulic brake category. With all the complaints, I don't understand why there hasn't been an investigation! Does anyone know how to get this done?
  15. Feb 15, 2015 at 11:53 AM
    #1535
    BlueT
    NorthEast
    Because ABS not slowing down a vehicle is deemed by government "normal" Thats why there is a note that ABS in bad condition can extend braking distance by a lot.
    Therefore stupid ABS is stupid.
  16. Feb 16, 2015 at 8:00 PM
    #1536
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    I have a brand new Nissan Rogue, the ABS is great, works awesome, not scary, it is very predictable and i like it. I think it helps. I have a Toyota SCION TC, the abs is very effective, and works very well in snow, ice, rain etc, just like the Nissan Rogue. I have a 08 Toyota Tacoma, the ABS IS ABSOLUTELY F'N DANGEROUS. So bad I refuse to let anyone drive my truck in snow or icey conditions. Straight up, dangerous. My ABS recenly quit working and it's the best damn thing that has happened to this truck.
    Oh, and yes, I filed a complaint with toyota the first winter I had teh truck. They acted like I was the only person to ever mention such a thing.
    And to the naysayers; this is not a tire thing, this is not a driver thing, this is not a few isolated incidents....this is a PROBLEM WITH THE ABS SYSTEM. You all can back up toyota all you want, and blame the driver, or the tires or whatever you want so you don't have to face the facts. I don't know if they fixed it after my trucks year 2008, but god help the owners who let others drive their trucks in snow and ice. You have to completely change how you are used to driving a typical vehicle on snow. There is nothing SAFE about my ABS system.
  17. Feb 17, 2015 at 6:38 AM
    #1537
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Seen a 14' tacoma off the road in a ditch this weekend, buried up to the roof in snow. I offered the man & his wife a ride and the first thing he told me was the ABS came on and he completely lost control. Thank god I have an off-road with the ABS killswitch, best mod yet
  18. Feb 17, 2015 at 7:07 AM
    #1538
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I agree with every word of this, and you do have to totally change the way you drive versus other vehicles.
    I'm on my third 2nd gen, and every one of them has been like that.
    My FJ did not share this trait. It was above and beyond excellent in the snow, especially in regard to braking.
  19. Feb 17, 2015 at 8:48 AM
    #1539
    simplespirit
    simplespirit Well-Known Member
    WNC
    20 DC TRD OR
    FWIW - I drove in to work this morning after the ice storm that hit last night. My driveway and the street I'm on was a solid sheet of ice as was the parking lot at my office. The secondary streets were mostly ok but with ice patches in shady areas. I'm also on OEM Rugged Trails (granted they're newish with ~2400 miles on them). I kept waiting on the tires to slip and/or the ABS to kick in and cause me to slide off the road but neither ever happened. I spent most of the time in 2wd with occasional 4hi. I drive a 2014 TRD OR if that matters.
  20. Feb 17, 2015 at 8:53 AM
    #1540
    rngrchad
    08 Rugged Trail TRD
    That's good news! Maybe they fixed or adjusted their flawed ABS breaking system of years past.
