ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 17, 2015 at 11:22 AM
    #1541
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Don't get to confident, my 2013 TRD OR has had sensitive ABS issues a couple times on a completely stock truck. But that's all it's been, a couple random times over a 2.5 year period. I've tried to reproduce the issue in the exact same conditions as it has happened in with no luck.
    I wouldn't rule out the possibility of it popping up a year or two down the road, out of the blue, and biting you in the ass when your least expecting it.
  2. Feb 17, 2015 at 11:51 AM
    #1542
    Sledhauler
    Sledhauler Well-Known Member
    Derek
    MD
    13 DCSB TRD Sport 4X4
    I noticed a few days ago in dry conditions what seemed to be a quicker brake response and feel then normal. It only happened once and didn't cause any issues other then me stopping quicker but its got me wondering if whatever happen is the culprit of the snow condition abs issue. I barely touched the pedal but felt like I hit them hard, in snow conditions this would cause the abs to react.
  3. Feb 17, 2015 at 11:54 AM
    #1543
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I think the fact that this thread is 86 pages long, indicates that something is amiss with the ABS on this truck.
  4. Feb 23, 2015 at 10:18 AM
    #1544
    inouk
    inouk Well-Known Member
    Hi,
    There's a spot where my Tacoma will almost alway pass through, an junction on a steep grade when going downhill. There are some patch of ice, asphalt and snow. Kind of "all dress". It scared the hell out of me two times and it was two times too many. Even going down slowly, it still kicks in and it completely removes brakes. I mean, not brakes at all, even hard pressing brake pedal. On some other areas, all cars were able to stop but not me, even if I have top rated true winter tires (Bridgestone Blizzak DM-V1). It's enough, I fixed it by removing the fuse.
    Two weeks ago, I bought a F-150 4x4, even if ABS kicks in that spot, it stops way before stop sign. ABS is much more better designed on this truck. I can even go faster and it still stops.
    Definitely, ABS on Tacoma is too sensitive in winter and on dirt roads.
    Just wanted to share my experience.
  5. Feb 23, 2015 at 11:09 AM
    #1545
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    And there are 393 Threads on Tacoma World with ABS in the title. Lots and lots of complaints.
  6. Feb 23, 2015 at 11:17 AM
    #1546
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yeah I think whats hard is getting NHTSA to look into Toyota software for this.
    NHTSA believes (extended braking with ABS) is normal, so Toyota thinks its normal. Yet people ending up t boned and in ditches.
    :rolleyes:
  7. Feb 24, 2015 at 11:26 AM
    #1547
    Sbasser
    Sbasser Active Member
    Renton Washington
    TRD Off Road 4x4
    Trailer pkg. 6 spd.
    I was recently thinking that my brakes ('06 Tacoma 4x4 Access cab 4.0L with 6 spd) were not working very well. I thought about this for a few minutes and realized that because my driveway is short and not very steep, I was not using the brakes when backing up very much. So next time I drove it, I purposely slammed the brakes hard about a half dozen times (while backing) to make the self-adjusting on the rear drums do its thing. Helped a ton.
    My brakes have been replaced once. When they seat into the drums, they really need a bit of an adjustment. There is an automatic adjusting feature, but a lot of people never use the brakes hard enough in reverse to make it function. Try that!
  8. Feb 24, 2015 at 11:33 AM
    #1548
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I finally sold my 2007 on Friday and picked up a 2015. Are people still experiencing this problem on the latest production Tacomas? I'll try to test it out maybe tomorrow by trying to recreate the circumstances where I know it always used to happen on my 2007.
  9. Feb 24, 2015 at 11:40 AM
    #1549
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    So I didn't really think much of this topic until yesterday when my ABS had me rolling into a busy intersection. I knew I wasn't going to get hit at that moment but still extremely frustrating. I had my foot pressing as hard as I could because I was so pissed and I believe the ABS shuts off once you're under a certain speed (maybe 2 or 3mph?) because when it did my truck came to a stop very quickly... This indicated to me that this particular area was not that slippery and the ABS on these trucks is quite intrusive
  10. Feb 24, 2015 at 5:08 PM
    #1550
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    On my 2012 the problem still existed(until I pulled the fuse). I don't think Toyota changed anything with the abs besides adding TRAC/ALSD/VSC. Think about it, other car companies are making cars that can park themselves and hit the brakes for you in emergencies and Toyota can't make a good abs system (not that I would want either of those features).
  11. Feb 24, 2015 at 5:15 PM
    #1551
    simplespirit
    simplespirit Well-Known Member
    WNC
    20 DC TRD OR
    We had another 2-3" fall last night and I drove in early this morning on my crappy OEM Rugged Fails. ABS never came on but my traction control light did at one point while in 2wd. Supposed to get another 3-5" tomorrow night.
  12. Feb 24, 2015 at 8:22 PM
    #1552
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Toyota doesn't make any ABS Systems. They purchase them from suppliers.
  13. Feb 24, 2015 at 8:29 PM
    #1553
    joshd
    joshd Well-Known Member
    Josh
    San Pedro, CA
    2011 tacoma trd sport
    SAW coilovers, T/C upper arms, maxtrac spindles, deaver leafs, Fox remote resivoir shocks, icon bumps and a bunch of lights
    Yes but toyota calabrates every model individually during there pre product testing. it's is not a off the shelf program even though it might be an off the shelf part.
  14. Feb 24, 2015 at 9:07 PM
    #1554
    Dougj
    Dougj New Guy
    Doug
    Prather, CA
    Interesting thread. I searched for this because of the way my brakes worked in the snow this weekend.
    The ABS system seems to be WAY to sensitive, as others are reporting. My first clue was while going down a moderate hill, paved road, about 8" of fresh but wet snow. At about 15 MPH I applied light braking and the ABS immediately kicked in, continuously moderating brake pressure to the point that the truck simply continued at nearly the same speed, taking FAR, FAR longer to stop than was appropriate for the conditions. Since the road was deserted I tested the road surface by backing up the same area, stopping where it was at it's steepest, and then backing further up with no issue. (in 4WD of course) I then let the truck roll forward, lightly pressed the brakes, ABS went into overdrive again and we rolled all the way down to the flat, again. This was with me releasing the brakes and re-applying them as gently as I could. Later experimentation indicates that downshifting helps of course but I would say that the stopping distance in that situation was easily doubled from a normal stop without the hyperactive ABS.
    My wife said "Wow, it doesn't seem that slippery out here! Why is it doing that?" - It wasn't, and I don't know...
  15. Feb 24, 2015 at 9:57 PM
    #1555
    Jimmyh
    SC
    2012 Prerunner SR5
    The manufacturer programs and tests the ABS Controller to the specifications that are provided by Toyota. But my statement stands, Toyota doesn't make ABS Systems.
    What is Calabrate? Calibrate?
  16. Feb 24, 2015 at 10:03 PM
    #1556
    joshd
    Josh
    San Pedro, CA
    Yes sorry calibrate... and I wasn't saying toyota does make abs systems just that they are programed to toyotas specs. A hyperactive abs system is a calibration problem not a hardware problem.
  17. Feb 25, 2015 at 4:31 AM
    #1557
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Hyperactive, annoying, and dangerous.
  18. Feb 25, 2015 at 6:19 AM
    #1558
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    There's nothing better than easily reversible.
  19. Feb 25, 2015 at 6:25 AM
    #1559
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    All three of mine have been exactly the same way, with a myriad of different tires.
  20. Feb 25, 2015 at 6:46 AM
    #1560
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm saying that they all most likely do, but some owners don't experience any issues because of how they drive, and/or where they drive.
    If you live in Hawaii, you'll never experience the problem.
    If you drive very slow and cautiously, you'll never experience the problem.
