ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Feb 25, 2015 at 8:15 AM
    #1561
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm merely speculating, but I would bet money that I'm right. The trucks are consistently designed and manufactured. They are all very much the same. It stands to reason that the brakes are all the same too.
    I'm not about to make a formal claim with Toyota or with any other organization. Ain't got time fo dat yo.
    I'm aware of the issue, I've adjusted my driving style accordingly.
    Winter is almost over here, and my truck will be gone the minute that the 2016's hit the lots. Maybe the issue won't reappear in the new trucks. If it does, I'll adjust again.
  2. Feb 25, 2015 at 8:21 AM
    #1562
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    I think I've stated this before, but with new tires a week ago, added weight in the bed and whatnot. The best thing I can do to 'fix' the ABS issues that I seem to have, is to shift my automatic trans into N if I think I'm going to start to slide. I can feel a drastic difference in the rear 'pushing' me through the stop when I'm sliding in gear vs. stopping more quickly in N.
    It's a trick that I learned when driving old beat up '86 pickups in High School and it still works today.
  3. Feb 25, 2015 at 8:31 AM
    #1563
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  4. Feb 25, 2015 at 9:37 AM
    #1564
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  5. Feb 25, 2015 at 4:13 PM
    #1565
    Sledhauler
    Sledhauler Well-Known Member
    Derek
    MD
    13 DCSB TRD Sport 4X4
    And there lies the problem, this thread shows what would happen if you filed a complaint with anyone. Responses like black ice, you where driving to fast, that's how its suppose to act. Some things I've wondered, is there a mph that abs in not active, i.e. 2-3 or more mph, and what happens in the system when no traction is detected on any wheel? All in all I think the brake system is flat out awesome on dry/wet conditions and is probably why it sucks on snow/ice/mud and dirt.
  6. Feb 25, 2015 at 7:35 PM
    #1566
    Sledhauler
    Derek
    MD
    Well, I guess someone needs to start this off, so I will gladly complain to the dealership. I'll report back with their response.
  7. Feb 25, 2015 at 10:56 PM
    #1567
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And the NTSB.... They are the ones to make things happen....
    If I had a safety issue I would be screaming from the rooftops....
  8. Feb 26, 2015 at 4:38 AM
    #1568
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/index.xhtml
    If a few thousand Tacoma owners fill these out, Toyota would have to at least look into the issue.
    But filing a bunch of reports and maybe a few letters to our congresscritters might stimulate a closer look.
    Esp now with GM and Takata going on.
    Like with the ignition and airbag issues, there are going to be more 'component' issues than ever.
    Especially as cars get 'smarter'
    Everything talks to each.
    A component which work fine in 62 different models goes nuts when installed in the Puddlejumper 1500XLT, and the answer is buried somewhere in a 100 million lines of code.
  9. Feb 26, 2015 at 6:01 AM
    #1569
    fjrmurph
    fjrmurph Well-Known Member
    I live on 5 kilometers of dirt road, it has lots of hills and this time of year it is always covered in snow or ice (test track) yesterday I drove the road with ABS enabled I attempted emergency stops on different sections of the road, on hills and on level. The ABS does exactly as it was designed to do, at no time did I get slide ways, did it stop the truck "NO" I then pulled the fuse for ABS and drove the same road. I was able to stop the truck in shorter distances than I took with ABS enabled. I won't be reinstalling the fuse, I understand that this testing was subjective to my interpation of the braking distances.I have been driving for 40+ years. I slid off this road a month ago, did at least $1000.00 damage, the tree is doing fine it will make a full recovery. No big deal that's just plastic and metal, could have been a person instead of a tree. I will contact Toyota Canada and make a formal complaint. There should be a way to approach Toyota as a group, that would carry more weight than everyone making an individual complaint. has anyone checked other forums? I will try later today.i know some are going to adjust your driving style and that would work but I paid a lot of coin for this truck I think it should perform better than this !!!! My RANT. For the day
    Truck is a 2010 access cab TRD
  10. Feb 26, 2015 at 6:09 AM
    #1570
    sprucetrees
    sprucetrees Well-Known Member
    Ontario, Canada
    '̶0̶9̶ ̶D̶C̶S̶B̶ ̶T̶R̶D̶ ̶S̶p̶o̶rt̶ (RIP) '13 DCSB TRD Sport
    OME suspension, flippac, more to come...
    With 88 pages in this thread, and apparently 390+ threads with "ABS" in their title, I'm not about to get fully up to speed on this one.
    But, I ask:
    Are these ABS complaints Tacoma specific, or just general to ABS? Are people complaining on PriusWorld forums, too?
    Obviously an ABS system is a compromise. Less braking power (on loose surfaces), in favor of more braking power (on smooth surfaces) while maintaining steering.
  11. Feb 26, 2015 at 7:24 AM
    #1571
    fjrmurph
    I'm not interested in compromise, I drive on what you call (loose conditions) about three months a year! I can adjust my driving to help some, i can't adjust for the unplanned emergency stops. That's what scares me.
  12. Feb 26, 2015 at 7:56 AM
    #1572
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Tacoma specific.
    I've had ABS in other vehicles and while I'm still not really a fan it doesn't seem so detrimental. Many, many times with my 2007 Tacoma I had the brakes practically just stop working because a wheel tried to lock up for a moment. It just feels like 95% of your braking power is cut to all wheels when it happens. My other vehicles don't feel that way at all when the ABS kicks in.
  13. Feb 26, 2015 at 12:13 PM
    #1573
    fjrmurph
    Question sent to Toyota Canada. There is also "CANVAP" here in Canada.
    http://www.camvap.ca/about/
    They can help if you have an issue and can't get an a dealer or manufacturer to deal with it. There must be something similar south of the border.
  14. Feb 26, 2015 at 12:21 PM
    #1574
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    So there I was, on a Saturday night, driving down a lone strech of highway. Out of my right eye I see an object on the side of the road. It seems to be waddling its way right out onto the highway. I press my brakes and I get nothing. As its been snowing for hours at this point, I think to myself, it must be these damn Tacoma ABS brakes not working in the snow. I slide over what ever the obstrucion was in the road, right into the median. I get out and find a penguin, completely untouched. I pick up the little fella and go back to my truck. Behind me I see another Tacoma which seems to have met the same fate due to the faulty ABS brakes. In it is a beautiful woman name Sila. That woman became my wife, and if it werent for the brakes, it never would have happened.
  15. Feb 26, 2015 at 1:48 PM
    #1575
    Sledhauler
    Derek
    MD
    bahhaha, thanks good story:D
  16. Feb 26, 2015 at 1:58 PM
    #1576
    Sledhauler
    Derek
    MD
    Still can't find the answers to any cut off speed and what the systems does when no wheel has traction. I too have tried multiple times to make it act up with no success, it tends to lye in wait for that perfect moment. I did read that many offroaders pull the fuse in all vehicles equipped with abs and found some threads on other 4x4 toyotas with the same symptoms.
  17. Feb 26, 2015 at 5:47 PM
    #1577
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    All the times I've had the braking issue happen to me were under 10 MPH and light braking. I've tried recreating the problem many times and the only way I can purposefully get it to brake poorly is to lightly hit the brakes while going slow. If I slam on the brakes the ABS pulses like it should and I stop fine but when lightly braking it will just do its non-braking coasting nonsense with no ABS pulsing. I've never had another ABS car behave like this
  18. Feb 26, 2015 at 5:55 PM
    #1578
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    KB Voodoo, you Sir, are EXACTLY correct in your statement. All those tacomas down south won't ever experience the issue. It's us Northerners or guys who are running trucks in cold snowy climates that are at risk of ABS causing a fatal or catastrophic accident. I pull my fuse anytime one of my family members is going to drive my truck in the snow because the ABS is just taht dangerous. I warn them before hand that the truck no longer has ABS but its safer than the stock alternative. You people who don't experience it aren't spending much time in inclimate winter weather conditions. I experience a possible dangerious ABS condition nearly ever single time I have driven my truck in bad winter weather. I am a professional Class A CDL driver, with doubles, triples tankers and hazmat. I drive a Kenworth T800 every single day. These Tacoma's ABS is a death sentence.
  19. Feb 26, 2015 at 6:07 PM
    #1579
    Turd Ferguson
    Taxachusetts
    I just filled out the form. It only takes a few minutes. Maybe they'll investigate the issue if everyone else on this thread fills it out too.
  20. Feb 27, 2015 at 5:40 AM
    #1580
    inouk
    inouk Well-Known Member
    Exactly my issue. NO pulsing. NO brakes. Not at all . Tacoma was just coasting. It's isn't even slowing down!
    That is we're trying to say.
