ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Jan 8, 2010 at 9:06 AM
    #141
    98tacoma27
    Ben
    Not Beech Creek
    My auto does it, but it's a 05 Tundy. I am not sure if they share the same system.
  2. Jan 8, 2010 at 9:08 AM
    #142
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I forgot to mention. I own a 2007 Civic ex auto and the ABS feels the same on that car as it does in my truck. The systems may be made by the same company, I don't know, but other than being too sensitive for my taste, I'd still rather have ABS than not have it.
  3. Jan 8, 2010 at 9:09 AM
    #143
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I would say every time I've had this happen, I've either had the clutch pedal pushed in or I was in neutral. The only reason I can say that confidently is because each time it was a problem was when I was approaching a stop, and typically at a speed below what 1st gear at idle would have me doing.
    Tire pressure is good. I haven't checked in the past couple weeks, but I did readjust them for winter maybe a month ago or so, and I don't think they've changed any since then.
    Truck was just recently inspected, and they check the brakes then. They said they were good to go. I don't think any kind of wear has anything to do with it though, because I had this complaint right from the start within a month of buying it new in February 2007.
    I did consider contacting the insurance company and asking about the ABS. As someone else said, not all vehicles have ABS, but I figure ABS is probably listed as a safety feature that affects what my rates are.
    I would say in the three years I've had the truck, there have been about four times where this ABS has put me in what could have been a dangerous situation. I've been very lucky each time that there were either no cars present or they were far enough away that I was able to avoid them. The fact that it happens so infrequently though is also a problem, because I will have a hard time getting a dealership to see the problem and then admit it's a problem. :(
  4. Jan 8, 2010 at 9:12 AM
    #144
    NAAC3TACO
    2014 SR5 DCLB 4x4
    My truck is a manual and the ABS acts the same whether I have the clutch pushed in or not. Usually when I'm braking hard, the clutch is pushed in to prevent a stall, but that takes away engine braking that you get with autos or manuals when they are in gear. Maybe next time I will try to wait until the last second to push in the clutch and see if that makes any difference.
  5. Jan 8, 2010 at 9:15 AM
    #145
    PA452
    Western PA
    Do you know offhand is that can be done without a locker?
  6. Jan 8, 2010 at 9:16 AM
    #146
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Yes, you can search TTORA without a locker. :p
  7. Jan 8, 2010 at 9:17 AM
    #147
    PA452
    Western PA
  8. Jan 8, 2010 at 9:18 AM
    #148
    mjp2
    NJ
  9. Jan 8, 2010 at 3:23 PM
    #149
    jscrub
    jscrub Active Member
  10. Jan 8, 2010 at 3:34 PM
    #150
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    Is there a trick I'm not doing? If the ABS kicks in, TAKE YOUR FOOT OFF THE BRAKE. Then reapply gently, if you mash the pedal or freeze up and floor the pedal, yeah, you'll slide right through that intersection or whatever.
    But yeah, the ABS does seem to kick in a little quick for my taste. I wonder if it could be disabled without throwing a light?
  11. Jan 8, 2010 at 3:48 PM
    #151
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    On a side not...
    Anyone who does not want the ABS to work.... Pump the brakes with your foot like we used to do in the older cars. That'll prevent the ABS from working properly.
    If you want ABS to work - then put your foot on the brakes and leave it there - DO NOT PUMP THE BRAKES.
    Problem solved.
  12. Jan 8, 2010 at 3:48 PM
    #152
    jmb1985
    jmb1985 Active Member
    Middletown NY
    06 DCSB
    It all depends on the driver. I'm Pretty aggressive driver in the snow. I can control my vehicles perfectly in the snow. Some people who are more cautious in bad weather tend to give themselves more room to stop so don't have to apply the brakes as harsh. Tires play a huge roll. From my stock tires I went to brt mud terrains n I think the abs only kicked in once since n iwas driving like a lunatic. IMHO, the factory settings are a little to sensative.
  13. Jan 8, 2010 at 4:02 PM
    #153
    aktaco22
    aktaco22 Member
    Aaron
    Pittsburgh
    05 DC TRD Off-Road
    3" Toytec Lift Debadged Tail Gate Clear Headlights Dick Cepek DC-1 265/75-16 Nitto TG's
    Nice Find!
    Also remember that the stock tires are complete garbage! I remember my first winter with my 05 DC Off-Road. I was all over the place, sliding through intersections, trying to make turns and kept going straight, ABS was kicking in like crazy... Heck they were even bad with just rain. I have a set of Nitto TG's I run in the summer and I run Mastercraft Courser MSR's in the winter, basically an all terrain snow tire. I rarely have ABS kick in unless I'm on solid ice nor do I use 4WD that much... Remember that tires can make a huge difference they are the only connection you have with the road...
    If you're sliding and ABS kicks in you've obviously lost traction and even if you didn't have ABS you still lost traction, so guess what the end result is, you're not stopping either way!
  14. Jan 8, 2010 at 4:05 PM
    #154
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Sadly, only if the rear diff. is locked does the ABS shut off in our Tacomas. It was a pain four wheeling in my '05 with the ABS not letting me stop when I wanted to! So far the 2010 hasn't acted up... maybe they fixed it?
  15. Jan 8, 2010 at 4:05 PM
    #155
    PA452
    Western PA
    Yep. The problem is when this ABS kicks in and you weren't sliding to begin with.
  16. Jan 8, 2010 at 5:00 PM
    #156
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    PA452, I was wondering if you'll pop that ABS fuse out and see what happens. :D
    If it works you could put the fuse back in when the snow/ice is gone.
  17. Jan 8, 2010 at 5:03 PM
    #157
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I just pop out the fuse when i dont want ABS. 30 second job and I dont have to solder or tap any wires.
  18. Jan 8, 2010 at 5:12 PM
    #158
    Crom
    Nick
    San Diego, CA
    Millions
    Awesome. Your first hand experience is exactly what's needed.
    Just to clarify your talking about the 30A ABS fuse in the engine compartment fuse/relay box right?
  19. Jan 8, 2010 at 5:14 PM
    #159
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ exactly, ask anyone who goes to Pismo with me, I always pop mine out. I love it! I just smash the brakes and the truck digs in like a foot into the sand, stops me dead in the tracks. No ABS telling me I cant brake or anything
  20. Jan 8, 2010 at 5:26 PM
    #160
    Crom
    Nick
    San Diego, CA
    Millions
    +Reps sent to you! ABS in the sand was driving me nuts! :goingcrazy: Now I can dig in! :cool: Awesomenss! :headbang:
