ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Mar 6, 2015 at 2:28 PM
    #1701
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Just to review:
    This ABS problem is most likely a software issues with the Tacoma
    Not all Tacoma's seem to be universally affected
    Most of us will probably never have this issue. For those that do there is no clear option on how to "fix" it. You're left with trying to adjust the system with better tires and a safer driving style to try not to set off the problem or disabling the ABS/VSC. Disabling the ABS/VSC can have it's own set of conditions that could put you in a hazardous situation.
    Okay, now back to another couple of pages of useless banter before I retype this again.
  2. Mar 6, 2015 at 2:31 PM
    #1702
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You forgot " whenever people try to dismiss the issue they substitute the word " ice " in place of " snow ""
  3. Mar 6, 2015 at 2:43 PM
    #1703
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    You know snow is a frozen water just like ice, just aerated . And snow and ice can be in the same plane of existence.
  4. Mar 6, 2015 at 2:58 PM
    #1704
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    yeah, if you say so. If i had said 4wh, would you have said thats "4wh push?" Theres over 90 pages of abs posts behind me :notsure:
  5. Mar 6, 2015 at 3:03 PM
    #1705
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Airliners have had ABS since the 1960s. Like everything else on an airplane it can be disabled. An airline pilot told me it didn't work on snowy, slushy runways (couldn't stop), he always turned it off under those conditions.
    I want to install an ABS disable switch on my 2009 Regular Cab. Any recommendations from those with experience?
    I have driven vehicles without ABS on ice so I know what to expect.
  6. Mar 6, 2015 at 3:05 PM
    #1706
    BlazeTaco
    PA
    4.0l 6sp SR5
    For your info post #1778 skiergd011013
  7. Mar 6, 2015 at 3:22 PM
    #1707
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Hmmm...last time I posted here I asked if people had tried different brake pads to affect this situation, but I didn't see any responses.
    so, anybody?
    Also, I've tried several times to get my truck to "lose" the brakes in an ABS situation, but so far I still haven't been able to.
    SO now I wonder how many Tacomas will crash this winter, and if it will be enough that the insurance industry gets the NTSB to move on a recall.
    Regarding autos, I learned to drive in north Minnesota, and we were always taught to shift to neutral coming to a stop with an auto. I have not been doing that, and I've tried it with the A/C clutch both on and off, as I believe the ECU bumps the idle speed when the A/C or defroster is running.
    BTW, I was a professional driver when I was 18. I drove from Ogden to Dugway delivering drygoods for the AAFES. I got paid $3.65/hr, thus I was a pro. That's the definition. You don't have to run 24hrs at LeMans to be a pro. You just have to get paid to drive.
    Being a pro doesn't make you good, however. There are lots of bad pros in every field.
  8. Mar 6, 2015 at 3:25 PM
    #1708
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I still have yet to experience what you guys are talking about here. I've covered a lot of snow and icy roads this winter. A light applying of the brakes leads to a smooth controlled stop. I've went up and down hills, through 12+ inches of unplowed snow getting back into the cabin.
    Stopping on ice isn't going to happen with or without ABS. I can't believe 95 pages beating a dead horse.
  9. Mar 6, 2015 at 3:47 PM
    #1709
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Well, clearly it's happening to people. Just because it hasn't happened to us, could be luck, or circumstances, or "sample variations" in manufacturing.
    But IMHO it's no myth.
    It is, however, a technical enough issue that there will be a lot of testimony before a recall is issued.
  10. Mar 6, 2015 at 4:18 PM
    #1710
    OZ-T
    Peter North
    British Columbia
    Yes they can , but a snow covered road is not automatically an ice covered road
  11. Mar 6, 2015 at 4:21 PM
    #1711
    OZ-T
    Peter North
    British Columbia
    :rolleyes:
    snow
  12. Mar 6, 2015 at 4:21 PM
    #1712
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I can pump my brakes faster than an ABS system can.......
  13. Mar 6, 2015 at 4:24 PM
    #1713
    OZ-T
    Peter North
    British Columbia
    pretty sure nobody has made that claim
  14. Mar 6, 2015 at 4:25 PM
    #1714
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Went for something new.
  15. Mar 6, 2015 at 4:26 PM
    #1715
    OZ-T
    Peter North
    British Columbia
    that's what I said
  16. Mar 6, 2015 at 4:28 PM
    #1716
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im working on heated tires, so the ABS doesn't fuck up stopping on snow/ice.
  17. Mar 6, 2015 at 4:32 PM
    #1717
    OZ-T
    Peter North
    British Columbia
    Too late
    Patent US6350963
  18. Mar 6, 2015 at 4:33 PM
    #1718
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine will be actually ON fire........
  19. Mar 6, 2015 at 4:47 PM
    #1719
    Chris15sr5
    Chris15sr5 Well-Known Member
    SoCal
    SR5 4x4 DCLB
    I had similar issues with my 04 4runner 4x4. I thought it was from the lack of having stability control or something, where's my 09 jeep wrangler unlimited 4x4 had no issues at all. I had both vehicles back to back in the snow and the jeep felt more stable and stopped with confidence when driven within means. Both had normal AT tires.
    Haven't driven the new taco in the snow yet.
  20. Mar 6, 2015 at 5:14 PM
    #1720
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    You must have been driving to fast for conditions and slammed on your brakes. Rear wheel drive push isn't a real problem, I had an 01 s10 pickup and it never did that. :rolleyes:
    Honestly though, I've never heard of anyone ever needing to put a vehicle in neutral when coming to a stop on snow or any other conditions. It might help on these trucks though. I do know that while I own this Tacoma; I will have one hand on the shifter and one eye on the future ABS kill switch, whenever I'm braking in any kind of slippery conditions at low speeds.
