ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Jan 8, 2010 at 5:30 PM
    #161
    MTgirl
    Weesa
    Bob's secret mod lair
    ABS was never really tested in icy conditions - it was developed more for wet roads, not frozen ones. i know that both of my vehicles slide 10x's further if ABS kicks in. i have found that both vehicles have a sweet spot on the pedal - as long as i dont press too hard ABS will not engage.
    have you checked your brake pads lately? if you really have to stomp on the brakes you could have ABS kick in unnecessarily by passing that sweet spot due to bad brake pads.
  2. Jan 8, 2010 at 5:37 PM
    #162
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Nope, my pads are good. I know what you mean by the sweet spot though. I was experimenting with the ABS on my snow covered driveway today (1/4 mile long). I noticed that there seemed to be a point where I was getting some brake power applied to the wheels but would not let the ABS engage, just like you mentioned.
  3. Jan 8, 2010 at 6:01 PM
    #163
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    I wonder f you realized how close to the truth you were when you posted that. Only make it 5-10 kph.
    If you read your owners manual, you will see that ABS will not activate until the vehicle reaches 10 kph and will deactivate when speed drops below 5 kph. (That's 3 and 6 mph respectively.)
    When someone states that they are going incredibly slow and their ABS kicked in, I have to conclude that their incredibly slow is at least 3 and perhaps over 6 mph.
  4. Jan 8, 2010 at 6:08 PM
    #164
    HankB
    Hank
    near Chicago
    bone stock
    Citation?
    I cannot imagine that ABS has not been tested extensively over a range of conditions from dry and sticky through slicker than snot. Your claim makes no sense at all from a product development standpoint, but I am willing to consider it if you can back it up.
  5. Jan 8, 2010 at 6:39 PM
    #165
    MTgirl
    Weesa
    Insurance Institute for Highway Safety. I'm feeling lazy and don't want to look for the exact study but when ABS was first introduced they tested identical models of vehicles one with ABS and one without. Each of the cars were run on wet roads and dry roads to compare handling, stopping distances, etc. In the end the vehcles with ABS showed more favorable results. Then, after a few years of ABS being available on nearly every vehicle made there was a sharp increase in fatal accidents. Only then did the IIHS and others start to test the ABS systems on icy roads and learned how drastically different they reacted.
  6. Jan 8, 2010 at 8:15 PM
    #166
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You're specialist is probably referring to traction control. When you want to race a corvette - you turn the traction control off. In fact, there's 3 variations of settings you can choose from.
    All vehicles have ABS.
  7. Jan 9, 2010 at 7:51 AM
    #167
    HankB
    Hank
    near Chicago
    bone stock
    I looked, couldn't find it and remain skeptical.
  8. Jan 9, 2010 at 11:02 AM
    #168
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
  9. Feb 4, 2010 at 5:48 AM
    #169
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
  10. Feb 4, 2010 at 6:17 AM
    #170
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I agree ABS feels like a nuisance, but consider that it really only comes on when there is no traction. So while you had traction in the lot , the road had none, could be packed under fresh=slide, lots of variables.
    Could be tires too, the best offroad MT tire isnt truly good for pack snow or ice,unless its severe weather rated/siped, and can still slide. Snow conditions change rapidly with traffic quantity, bridges, altitude, sanding/salting etc. Its not that the tires are bad, just not suited for pack snow/ice.
    Going downhill in a traveled traffic lane will cause studded tires or snow tires to slide at times, gravity wins.
    I do snow and ice plowing /road closures for the city, see all the tires fail on certain hills with no exceptions.Tehy make it up the hill, but later they go down and slide of the road.
    Take no offense but the worst offenders are 4wd any make who say before they go down.." its a 4 wheeler and i have MT tires/AT tires", next big offender is the suburu that didnt make it either, in front of them.
    p.s. ABS, is it claimed to actually stop shorter, or claimed to stop safely. If i'm not mistaken they focus on it stopping you safely
  11. Feb 4, 2010 at 6:25 AM
    #171
    wht09taco
    wht09taco Well-Known Member
    James
    Northern NY
    White 09 v6 4x4 sport
    I have had no problem with my brakes .... so far.... but I don't like one thing is that the anti lock doesn't seem to work below 5 mph... I don't understand... I was told by a heavy equip Mechanic ( Ford lover ) that antilock brakes don't work below 5 or 10 mph.... WTF .... I work at a place where all day long heavy equip is going in and out of a driveway that is down hill to highway and every vehicle we have does exactly the same thing.... Seems to be slowing nicely down to about 5-10 mph and then locks the brakes and tries to slide out onto the highway....
  12. Feb 4, 2010 at 6:39 AM
    #172
    IndigoTaco
    I've had nothing but 4wd's since i've been driving and NOT ONE has had the braking issues this truck has. Not abilities, it's the system itself.
  13. Feb 4, 2010 at 6:43 AM
    #173
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    I had a problem that almost made me crap my pants. I was getting off the interstate, coming down the offramp. I drove over a cattle grate at the bottom while applying the brakes. ABS kicked in and I drove straight through the stop sign. Scared the crap out of me. Thank goodness it was at like 2am and there were no other cars around.
  14. Feb 4, 2010 at 7:17 AM
    #174
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not really, i have 07 purchased in end of 06. In winter I travel daily down the 30 degree slope covered in ice/snow and I dont get that problem. Sure when road ends up in pure ice there is little abs action but nothing dramatic. I also run stock tires:confused:
  15. Feb 4, 2010 at 8:51 AM
    #175
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This thread has been played out.:facepalm: So many issues here, some solved, some remain... Others just defending their points of view. :facepalm:
  16. Feb 4, 2010 at 8:56 AM
    #176
    BlueT
    NorthEast
  17. Feb 4, 2010 at 9:10 AM
    #177
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Actually it is the opposite on my truck.
    If I am going fast and cause the ABS to kick in it works as designed, I have reduced braking until I either come to a stop or the lack of traction is no longer a factor, but if I am going less then 10 mph and cause a ABS situation I lose brakes, it's as if I just pushed the clutch in with my foot off the brakes and I just coast.
    Sure people will come in here and say "Dude ABS isn't a factor at those low of speeds" but it is on my truck and according to the dealer it is "Normal"
    So I just say it's Normal Fucked Up
  18. Feb 4, 2010 at 9:33 AM
    #178
    PropJet
    PropJet Well-Known Member
    KS
    '09 DC TRD Off Road
    ToyTec Ultimate Lift Kit, Moto Metal 955's, GoodYear DuraTrac 265/75/16's, N-Fab Nerf Bar
    I only read about the first 100 or so posts and gave up after that, but here's my summary of this thread...
    "My ABS is putting me in dangerous situations."
    "It's not working right. You should take it to the dealer to get checked out."
    "But I'm having problems with the ABS... it shouldn't be doing this."
    "Take it to the dealer."
    "But it activated on dry pavement."
    "But..."
    "Why haven't you taken it to the dealer yet???"
    "Because I'm having to defend myself against these accusations. And oh, by the way, my ABS is not working like it should."
    :facepalm:
  19. Feb 4, 2010 at 9:38 AM
    #179
    Crom
    Nick
    San Diego, CA
    Millions
    Propjet, good summary. One important detail to add.
    We learned that we could pop the ABS fuse out to disable the system.
    Thanks to blackhawke88 :yay:
  20. Feb 4, 2010 at 10:30 AM
    #180
    Fortech
    CANADA
    I also have this problem.
    And before anyone accuses me of having bad tires, I run BFG All Terrains in the summer and a dedicated ice radial with studs in the winter. Never any trouble in the summer except for very loose or muddy surfaces. In winter the system cause me all kinds of grief and mostly below 20 mph.
    What really ticks me off is if I am driving down a street with the left two tires on dry pavement, and the two right tires on ice - the ABS still activates and increases my stopping distance significantly. Wanna argue? I regularly disable the ABS with the grey wire mod for the rear locker in such instances. I've done trials dozens of times and the truck ALWAYS stops quicker WITHOUT ABS.
    The ABS shouldn't be able to be activated below 15 mph. The current cut off point is 5 mph I believe.
