ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Nov 19, 2015 at 2:41 PM
    #1901
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I think I need a translator.
  2. Nov 19, 2015 at 2:44 PM
    #1902
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Tunable mirrors again, I'm out.
    DoorDing likes this.
  3. Nov 19, 2015 at 8:06 PM
    #1903
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    It's obvious the ABS program reduces line pressure so much that the brakes don't effectively work. That is an issue with the programming that runs the ABS pump and feedback from each brake/rotor assy.
    To somehow claim that older ABS systems that utilized front rotors/rear drums didn't work is ridiculous. Hell, GM had a ABS system [though somewhat primitive] in the very early 70s [or later 60s], I know our Toronado had it and it DID work. I believe Teves designed it.
    What it did not do is the traction control that modern ABS usually has and it didn't adjust line pressures for each wheel and feedback typefrom each wheel was not the greatest.
    However, to claim that Disc/drum systems didn't have effective ABS systems, especially in the past 20 years, is just not correct. Now if you claim that Toyota doesn't have one that works well, well, I won't disagree with you because their seems to be a plethora of complaints that other brands do not have.
    I've heard similar complaints with the FJC which has 4 wheel disc brakes so I doubt it's as much the type of brakes as it is the programming, feedback, and pressure control.
    archerm3 and Sterdog like this.
  4. Nov 19, 2015 at 8:31 PM
    #1904
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I can't agree. I had a company truck last year - a 2013 Chevy 1500 with rear drum brakes - and while this was the ONLY area it functioned better than my Tacoma, it's ABS functioned very well, and still stopped very well once the ABS system began modulating that brakes. With inferior tires as well.
    I have a strange feeling the 4 channels of my ABS system might be crossed - ie, the front's modulating for rear slippage, or even crossed side to side. I might spend some time messing around with it and see what I come up with - I do know it is as it left the factory, but that doesn't mean the brake plumbing or wiring of the sensor circuits is correct. In the meantime, my disable switch is handy.:bananadance:
    archerm3 likes this.
  5. Nov 20, 2015 at 6:03 AM
    #1905
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    if you were up here, you'd stop and look at our beautiful white pines:rolleyes:
  6. Nov 20, 2015 at 6:05 AM
    #1906
    skiergd011013
  7. Nov 20, 2015 at 6:10 AM
    #1907
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Ah fall. The leaves have fallen. There is snow in the forecast. BlueT is ranting about disc brakes and ABS. It's beautiful :p.... I'm out.
    23Skidoo likes this.
  8. Nov 20, 2015 at 6:26 AM
    #1908
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I've used DAC in my 2014...it's scary as f*ck and sounds like the truck is falling apart. But it works. It's a weird feeling to be clunking downhill with your foot off the brake.
  9. Nov 20, 2015 at 8:55 AM
    #1909
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I don't know about 2013 GM truck because its still brand new vehicle, but didn't older GM trucks had the same exact problems ? I believe there was even Technical bulletin for it. (I remember seeing ABS problems)
    Bottom line is it can not be ABS system because both TRD OR and regular trucks have the same exact problem.
    TRD OR uses what appears to be Toyota proprietary system, and the rest of trucks seems to be using Bosch common ABS system.
    If the problem was in the ABS system than only specific trucks would have problems, and not both TRD OR and regular trucks. Also since both Bosch-like system and TRD system are used on other Toyota trucks, and neither have problems clearly it can not be ABS unit.
    So what else is left there?
    What is the difference between Sequoia and Tacoma both running the same Bosch system?
    Well the only difference is drum brakes on the rear. Sequoia has no problems.
    Whats the difference between Land Cruiser or trail edition 4 runner and TRD OR ?
    Well the only difference is drum brakes on the rear. and neither 4runner Trail edition nor Land Cruiser has the same problems
    In fact you can swap system from 4runner or Sequoia to your truck with their code and it will still have the same problem.
    Therefore it can not be ABS unit itself.
    Since steel lines would not make any difference, and booster is the same, along side with front calipers pads, the only item that is different is the rear drum brakes.
    So it has to be that.
  10. Nov 20, 2015 at 1:26 PM
    #1910
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    How can you tell that winter is near on TW?
    The bitching about ABS starts up again.
    Clearwater Bill, Sterdog and DoorDing like this.
  11. Nov 20, 2015 at 1:30 PM
    #1911
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I tried 2 different abs disable mods posted here and have had no luck. I'll probably pull the fuse when the snow falls
  12. Nov 20, 2015 at 6:47 PM
    #1912
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    HAHAHA
    Don't tell BlewT that a 2013 chevy pickup had rear drum brakes because he won't believe you...He thinks everything from 1983 on except toyota pickup/tacoma has rear discs.
  13. Nov 20, 2015 at 6:50 PM
    #1913
    archerm3
    Nebraska
    Or maybe weight distribution of the vehicle, or tires size, or wheel/tire rotational mass/inertia, or tire traction, or suspension dive, or .......nah, it's gotta be some bullshit that blewt heard about reading a magazine.
  14. Nov 20, 2015 at 7:12 PM
    #1914
    skiergd011013
    it's no surprise you havn't experienced this in South Carolina.
  15. Nov 20, 2015 at 7:28 PM
    #1915
    landphil
    BC, Canada
    Tundra 5.7 mod
    EffYouSeeKay - now I remember why I quit posting and reading this dumb thread last year. Bye - hope my memory is better next October / November.
    Jimmyh and DoorDing like this.
  16. Nov 20, 2015 at 7:41 PM
    #1916
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  17. Nov 20, 2015 at 7:47 PM
    #1917
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    My fuse is already pulled.
  18. Nov 20, 2015 at 7:49 PM
    #1918
    skiergd011013
    that looks like one of the drawings in the old book "scary stories to tell in the dark":eek:
  19. Nov 20, 2015 at 8:33 PM
    #1919
    Jimmyh
    SC
    2012 Prerunner SR5
    Nope, Sitting on hands.
  20. Nov 20, 2015 at 8:35 PM
    #1920
    Jimmyh
    SC
    2012 Prerunner SR5
    Well according to skiergd011013, I obviously don't know jack sh!t.
