ABS & Parking brake light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdz2nutz, Jan 30, 2014.
  1. Jan 30, 2014 at 6:24 PM
    cdz2nutz
    cdz2nutz [OP] Member
    05 tacoma
    3" suspension lift & air bags
    I knocked ice off of rear axle only to have my ABS & parking brake light stuck on when I got back in truck . I have brakes but no ABS. Can someone tell me how to find sensor on rear ? I don't see anything obviously loose. Just 2 aggravating lights on my dash !!!!
  2. Jan 31, 2014 at 12:25 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They are bolted on to the front side of the Axle Hub Assembly. One on drivers side and one on passenger side.
    It should be fairly obvious when looking under the truck. It is the only component on the wheel hub with an electrical cable going to it.
    You probably damaged or unplugged the cable when knocking the ice off.
  3. Feb 2, 2014 at 5:51 AM
    cdz2nutz
    05 tacoma
    It was a loose ABS connector on right rear. Thanx a lot man.
