ABS problem
Discussion in 'Technical Chat' started by TheMountainTaco, Mar 12, 2022.
  1. Mar 12, 2022 at 7:13 PM
    TheMountainTaco
    TheMountainTaco [OP] Member
    Ivan
    2015 Toyota Tacoma
    Magnuson supercharger Bully Dog tuner K&N cold air intake CFS radiator Pedal Master throttle control Fox 2.5 remote reservoir coil overs/struts Archive shock relocation towers Archive garage hammer hangers Deaver leafs Dirt King upper/lower control arms Genesis dual battery kit C4 fab hybrid front bumper CBI rear high clearance bumper CBI skid plates Warn 10k winch
    Did some suspension work on the front and rear and now there’s a long list of abs codes. Do I need a new wire harness?
    C1405
    C1271
    C1272
    C1273
    C1274
    C1275
    C1276
    C1277
    C1278
    C1279
    C1280
    C1281
    C1282
  2. Mar 12, 2022 at 8:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What exactly did you do and did you try clearing the codes and seeing if they all come right back?
  3. Mar 12, 2022 at 8:37 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Check your wheel speed sensor wires, theres one to each wheel. They're pretty fragile so get damaged easily.
    TheMountainTaco[OP] likes this.
  4. Mar 12, 2022 at 8:47 PM
    TheMountainTaco
    Ivan
    2015 Toyota Tacoma
    If one of the wheel speed sensor wires was shot could it through a code for all four corners of the truck?
  5. Mar 12, 2022 at 8:48 PM
    TheMountainTaco
    Ivan
    2015 Toyota Tacoma
    New coil overs, upper and lower control arms as well.
  6. Mar 12, 2022 at 8:58 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    When you took the front knuckles off did you let them hang by the ABS wires?
  7. Mar 12, 2022 at 8:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think I'd clear the codes and see what comes back, it's possible some of those were set if the key was turned on with something unplugged.
    Key-Rei likes this.
  8. Mar 12, 2022 at 9:27 PM
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    I don't think so but I'm going by 3rd gen logic.
    Do this see what comes back. Also what lights you have lit on the dash?
  9. Mar 12, 2022 at 9:47 PM
    TheMountainTaco
    Ivan
    2015 Toyota Tacoma
    I hung them up with bailing wire. But they did get knocked around a bit, that’s probably where the problem is.
  10. Mar 12, 2022 at 10:08 PM
    Bishop84
    Bishop84 Well-Known Member
    ABS codes won't clear until repaired.
    And once repaired, they typically will self-clear.
    This is 100% harness related.
  11. Mar 12, 2022 at 10:10 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I bet a main harness is fried or you shorted something out and it blew a fuse disabling multiple ABS functions.
