ABS pump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxKOZMO, Jan 31, 2021.
  1. Jan 31, 2021 at 4:41 PM
    xxKOZMO
    xxKOZMO [OP] New Member
    Nick
    2021 White Tacoma TRD-OR SB
    Window Tint
    Hello. I have a 2021 TRD OR with a manual trans. I’ve noticed at times I can feel or here the abs actuator/pump kick on.. I’ve worked on cars for 19 years at nissan and never experienced this before. It doesn’t lock up my brakes or anything it just simply can be felt through the brake pedal that is has kicked on abs you can also hear it (my ear is also trained for noises). So it may not be noticeable to most people... has anyone else have has this?
  2. Jan 31, 2021 at 4:44 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Edit: Deleting my bad info.
    Refer to mr. @Dirk Diggler
    's correct answer below.
  3. Jan 31, 2021 at 4:58 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I think you're referring to the brake booster in the OR
    Kev250R, hiPSI, xxKOZMO[OP] and 3 others like this.
  4. Jan 31, 2021 at 5:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    How can any of us untrained savages hear something only a trained ear can hear?
    Lol it's not ABS. It's the booster, which only comes on the Pro and Off Road. The other models have standard brakes.
    BigWhiteTRD likes this.
  5. Jan 31, 2021 at 7:22 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Rather than a vacuum driven brake booster, the OR and Pro use an electric hydraulic pump with an pressure accumulator.
    It is assumed that this creates higher braking force than a vacuum booster and is required for restraining wheel spin for ATRAC, MTS, Crawl Control, etc in 4Lo.
    ShimStack likes this.
  6. Jan 31, 2021 at 7:50 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Also of note is that normal rear braking is entirely electro-hydraulic and not mechanical. So the pedal force from your foot (amplified via the hydraulic boost system) is directly pressurizing only fluid to the front calipers while the rear drums are completely "brake-by-wire". This means the hydraulic power system is constantly in use during normal driving. The hydraulic accumulator maintains system pressure for all the normal braking functions and drops with each application of the brakes so after a couple times the pump runs to re-pressurize the accumulator.
