ABS rant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sean266, Feb 23, 2012.
  1. Feb 24, 2012 at 10:06 AM
    #41
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This , and a beeper
  2. Feb 24, 2012 at 10:28 AM
    #42
    sean266
    sean266 [OP] Mr. Clean Moderator
    Thanks for your input. I'm having a buddy re-calibrate the VSC on Monday
  3. Feb 24, 2012 at 11:19 AM
    #43
    OZ-T
    Peter North
    British Columbia
    Go there with a 1/2 tank of gas and sit in the seat when the calibration is done
  4. Feb 24, 2012 at 5:44 PM
    #44
    sean266
    Can u elaborate on the reasoning for this?
  5. Feb 24, 2012 at 5:50 PM
    #45
    OZ-T
    Peter North
    British Columbia
    You will be setting the zero points for the yaw sensor when the recalibration is done , as we all know , the " taco lean " is from the driver , gas tank etc all being on one side . You as the driver will always be in the seat when driving so it makes sense to have that weight there when zeroing the system , the 1/2 tank of gas is the average weight you would carry in fuel , so is basically a neutral allowance for gas weight .
  6. Feb 25, 2012 at 1:51 PM
    #46
    inouk
    inouk Well-Known Member
    NHTSA says in 2005:
    Ref: http://www.nhtsa.gov/DOT/NHTSA/NRD/Multimedia/PDFs/VRTC/ca/capubs/ABSperformancefinalreport.pdf
    Emphasis mine.
    Automaticalling disabling ABS if car go below 15kp/h (10mph), would be a good compromise if on/off switch is out of question. 5mph is way too low and even with that, ABS still kicks in. According to the owner manual, it says that ABS will be disabled if speed go below around 5mph.
    ABS system isn't mandatory, unlike seat belts and air bags. In fact, NHTSA backed off about it seeing that ABS didn't really help in lowering accident rate in all situations.
    In fact, from what you're saying, does that mean that around 30% of sold cars (new) that doesn't have ABS system are dangerous?
    According to NHTSA report, in 2009:
    Page 10:
    But, if cars are equipped with stability control, which my truck doesn't have one:
    Page 11:
    About overall performance of ABS system in fatal crash (remember that this report was made on 2009):
    However, overall effect in all type of crash seems in favor of ABS system:
    Ref: http://www-nrd.nhtsa.dot.gov/Pubs/811182.PDF
    Conclusion: ABS isn't good on ice/snow and gravel roads and we should have a ABS disable switch, like ESP or ESC disable switch.
  7. Feb 25, 2012 at 5:39 PM
    #47
    OZ-T
    Peter North
    British Columbia
    Great post ^^
  8. Feb 26, 2012 at 3:56 PM
    #48
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Indeed!
  9. Mar 1, 2013 at 5:33 PM
    #49
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Yup.
  10. Mar 2, 2013 at 6:40 AM
    #50
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    For people worried about disabling their ABS I don't think they can hold you responsible for a blown fuse. That kind of thing happens all the time.
