ABS relocation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nikuraba29, Sep 16, 2017.
  1. Sep 16, 2017 at 6:58 PM
    Nikuraba29
    Nikuraba29 [OP] Well-Known Member
    Jacksonville, FL
    2016 LC200
    Anybody know how I can relocate the ABS unit so I can put in a second battery?
    Thanks,
    29
  2. Sep 17, 2017 at 8:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would find another location. Moving the ABS Controller is going to be VERY Problematic with the hard brake lines etc....
  3. Sep 17, 2017 at 10:28 AM
    Nikuraba29
    Jacksonville, FL
    2016 LC200
    True, but it takes up so much valuable real estate in the engine compartment.
  4. Sep 17, 2017 at 10:33 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I thought I saw the mod where you can put twin batteries side by side in the oem battery location.
  5. Sep 17, 2017 at 10:35 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Move both batteries to the bed, the rad support/inner fender can't handle even the stock battery if you wheel it..
  6. Sep 17, 2017 at 12:44 PM
    Pigpen
    Dan
    Northwest Montana
    If you want to really do it right, this is the route to go. Putting the second battery in the bed is an option too.
  7. Sep 17, 2017 at 2:34 PM
    Nikuraba29
    Jacksonville, FL
    2016 LC200
    @Bebop bought an OEM battery last year and it is huge. Can't justify replacing it yet. But the Bed is an idea.
  8. Dec 3, 2023 at 2:23 PM
    alasko
    alasko Member
    Humboldt
    2017 TRD off-road 4 door long bed
    I wouldn't touch your ABS. You are asking for problems in the future.
    GilbertOz likes this.
  9. Dec 3, 2023 at 4:20 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    My $0.02, sure I think the ABS module is relocatable if you make new hard lines and plumb it all up right, just gotta properly bleed it all out. Probably not a very difficult task.
    But it may much simpler and better to relocate one or both batteries to the bed. Easier to run cables instead of rerouting brake lines. Plus the above-mentioned weight issues, and not having to open up and mess with ABS at all. My only personal problem with this method is taking up bed space in the case of using my bed tent, etc. But that can be worked around. Alternately, (just spitballing here)you can get a couple of smaller lithium batteries, make some brackets, and mount them behind the rear bedsides, keeping bed space intact. Maybe even use the otherwise useless storage bins.
  10. Dec 3, 2023 at 4:29 PM
    Tacoma Mike
    Southern Maine
    Easiest is second battery in the bed. In the future if you want to go back to stock
    You unhook the cables from the engine bay. Done..
    I would NOT relocate.
