ABS Sensor Broken
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dgm, May 31, 2017.
  1. May 31, 2017 at 9:50 AM
    dgm
    dgm [OP] Active Member
    Daniel
    Indiana
    2023 Electric Lime Metallic Double Cab, TRD Sport, 4x4, 3.5, 6-Spd Manual, Tow Pkg
    KDMax Tune 10, Ironman Foam Cell Pro 3" Lift Stage 2, 285/17's, Black Rhino Kaizen Wheels, CMC, Rear AirBags, SofTopper, TacoRail, Cali Amber Fogs, Heated Seats, Tint, WD Hitch, Undercoat, Hood Struts, Running Boards, Screen Protection, Interior Equipment Magnets, Console Organizers, Kicker Amp & Door Speaker Replacements, Skar 10" Sub w/1000 watt amp, Door Panel Sound Deadening, Lots of Lime & Orange accents!
    Well, I broke my front left ABS Sensor trying to remove it to change the wheel bearing a little while back. Everything (except ABS, of course) works and drives fine, but I guess I really should replace that ABS sensor. Can anyone confirm that this is, indeed, the correct part? Toyota ABS Sensor. Also, assuming this is the correct part, why is this part $85 more from my local Toyota dealer?? ha.
    Oh... and then there's this one that's another $55 less. Worth $55 more for the Toyota part over the Dorman?
    Thanks!
