ABS Sensor Wire
Discussion in 'Technical Chat' started by matt_06trdtaco, Feb 18, 2009.
  1. Feb 18, 2009 at 3:20 AM
    matt_06trdtaco
    matt_06trdtaco [OP] Member
    Manitoba
    2006 TRD Off Road V6 4x4
    OEM Bed mat, OEM running boards
    A friend borrowed my truck this past weekend and managed to damage the rear ABS sensor wire, so now the ABS warning light and brake system warning light are constantly on while driving.
    Can I simply splice the wire back together and insulate with some heat shrink or should I have the entire wire assembly replaced?
    If it can be spliced back together, will the ABS warning light stay on and have to be reset with a code reader?
    Any help is greatly appreciated!
  2. Feb 18, 2009 at 4:23 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Are you out of warranty?
    How did you friend damage the ABS sensor wire?
  3. Feb 18, 2009 at 7:11 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Splice it back together and see what happens. I'd disconnect the battery first in case you blow a fuse or something somewhere while you're splicing it. Obviously, if there's more than one wire - make damn sure you're connecting the proper wires together.
    I'd use solder for a good splice and cover it up good with heat shrink.
    If you disconnect the battery while you're working on it, that might actually reset the light.
    Good Luck
    I've spliced O2 sensor wires in the past without any problems.
