ABS sucks in snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blueridge, Dec 29, 2012.
  1. Dec 29, 2012 at 7:32 PM
    #41
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ABS increases stopping distance in any weather.
  2. Dec 29, 2012 at 7:48 PM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Exactly
  3. Dec 29, 2012 at 7:51 PM
    #43
    OZ-T
    Peter North
    British Columbia
    ABS generally offers improved vehicle control and decreases stopping distances on dry and slippery surfaces for many drivers; however, on loose surfaces like gravel or snow-covered pavement, ABS can significantly increase braking distance .[1]
  4. Dec 29, 2012 at 7:56 PM
    #44
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    +1 here 2012 O/R TRD with OEM tires - did fine today in the snow. Was in 4x4 most of the time, turned it off for a bit in a parking lot so I could understand how she handles when the ass end lets loose.
    Coming from a RWD BMW M3 the Taco is a dream.
  5. Dec 29, 2012 at 7:57 PM
    #45
    OZ-T
    Peter North
    British Columbia
  6. Dec 29, 2012 at 8:01 PM
    #46
    OZ-T
    Peter North
    British Columbia
    I was , is that an issue ?
  7. Dec 29, 2012 at 8:07 PM
    #47
    81shark
    81shark Well-Known Member
    tires make a big difference. mine works ok with the snow tires. with regular tires, not as well. traction baby
  8. Dec 29, 2012 at 8:36 PM
    #48
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I'm not disputing any information given in this thread, I hate the ABS in the snow just as much as you guys do. It feels like it never lets go, or pulses like other systems do... BUT
    In low traction conditions, you guys should really consider 4WD and downshifting a gear before ever touching the brakes. When you're in 4WD and you downshift, stopping power is essentially 50/50 between front and rear axles. When you step on the brakes its more like 60/40 front and rear, respectively. Its much easier to brake the tires loose by using the brakes than downshifting.
    Drive safe, as you always should. When approaching a stop, downshift 1 gear, down two gears is acceptable if you're not bringing up the RPM's above say... 3,000 rpm. Lightly use your brakes to increase your stopping power, but you'll find you wont to use them as much. I've been able to stop much faster this way without triggering the ABS.
    Food for thought. I may look into this ABS kill switch for winter though, but in the summertime it has saved my ass once.
  9. Dec 29, 2012 at 8:37 PM
    #49
    OZ-T
    Peter North
    British Columbia
    Yep ^^^
  10. Dec 29, 2012 at 10:22 PM
    #50
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    My '06 DCSB base with the vaccuum booster is way oversensitive on snow and ice, I don't think its just the Sports. Decent tires help a lot, as do driving to conditions. Replacing my base tokico shocks with TRD billies helps some too, more on bumpy roads. That said, this ABS system doesn't seem to allow enough % of slippage to give any braking once it engages. It even engages at less than 10kph, where its of no real value. Compared to other modern ABS equipped vehicles I've driven without issue, I've found it downright scary a few times. ABS is indeed designed to give steering (directional control) priority over braking, to allow the driver to avoid a crash by steering around an obstacle, but it should modulate threshold braking at the same time, something that doesn't happen well in my experiences. Installing the disable switch was one of the best mods I've done on my tacoma, as I often combine snow and "off road" driving. And, with a flip of the switch, I have it enabled again for safety at higher speeds on road.
  11. Dec 29, 2012 at 10:25 PM
    #51
    OZ-T
    Peter North
    British Columbia
    ^^^ exactly
    There is no opportunity to utilize threshold braking at all
  12. Dec 29, 2012 at 10:44 PM
    #52
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Nods! Sometimes you have four tires, and sometimes you don't.
    Another note about ABS: It isn't neccesarily designed to bring your vehicle to a complete stop. One of its main functions is to keep your vehicle straight when you apply brakes - especially important when you are driving at speed.
    Impacting an object straight on with the designed crumple zone is better than an irregular collision at a slightly lower speed.
    Obviously the focus isn't on crashing your truck every time you hit the brakes in inclement weather...I'm just making an argument for why having ABS turned on at higher speeds is an intelligent choice.
  13. Dec 29, 2012 at 10:45 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Oh really ?
  14. Dec 29, 2012 at 10:54 PM
    #54
    OZ-T
    Peter North
    British Columbia
    VSC keeps the tail from overtaking the front
  15. Dec 29, 2012 at 10:56 PM
    #55
    pra4sno
    ORLY!
    At least, for this guy it keeps me lined up with whatever I'm about to smack into! :D
  16. Dec 29, 2012 at 11:06 PM
    #56
    pra4sno
    Has anyone checked with a Toyota tech to see if there is some adjustment in the current ABS they are fielding?
    I'm happy to look into it. Know a guy.
  17. Dec 29, 2012 at 11:09 PM
    #57
    landphil
    BC, Canada
    Tundra 5.7 mod
    I consider myself one of the lucky ones that don't have VSC (or any of the other ABS related functions like Trac/Atrac, auto LSD...), but my understanding is all these go down when the ABS is disabled. What I CAN say for certain, those systems will behave as they do on the Off Roads do when the diff is locked, as "my" disable method mimicks the signal the ABS unit receives from the switch in the locker actuator.
  18. Dec 29, 2012 at 11:11 PM
    #58
    OZ-T
    Peter North
    British Columbia
    :popcorn:
  19. Dec 29, 2012 at 11:19 PM
    #59
    landphil
    BC, Canada
    Tundra 5.7 mod
    I would change the wording to:
    the main request seems to be allowing more braking force to be applied once ABS activates, and that's a programming issue.
    Agreed that it is a programming issue, and IIRC, many have been told by dealers that there is nothing that they can change there. Am I surprised? :cool:
  20. Dec 29, 2012 at 11:20 PM
    #60
    OZ-T
    Peter North
    British Columbia
