ABS/Traction control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doug86, Jul 11, 2010.
  1. Jul 11, 2010 at 10:17 AM
    Doug86
    Doug86 [OP] Member
    Doug
    Greater Boston
    2010 Tacoma
    I have a 2010 4 door long bed, 4X4 and have been having issues with the traction control kicking in too often. I have a racing back ground so when I attempt to have some fun on off/on ramps or windy roads traction control will kick in and screw up a good line. It mainly happens when I get a little bit of a slide front or rear, sometimes both, but I am fine and in control. I am looking for a way to switch off all of the electronics, ABS is fine, but the traction control has to go. Anyone have experience with this?
    Thanks,
    Doug
  2. Jul 11, 2010 at 10:42 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Yeah, slow down, or buy a car.
  3. Jul 11, 2010 at 10:56 AM
    hansonian
    hansonian swims with fishes
    Tampa, FL
    2007 Double Cab PreRunner SR5
    Stock
    on my previous vehicle (08 Jeep Wrangler) you could turn the traction control off with a series of turning the ignition key, presses the accelerator and turning the steering wheel (PITA). i'm sure somewhere in the system there's a combination of actions that should disable it. i know this doesn't help but maybe it's a step in the right direction.
    personally i see it as a truck not a hot rod. if i want to go fast and slide around i'll buy something made for it.
  4. Jul 11, 2010 at 10:58 AM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    press and hold the traction control button till it shows the little truck burning out thing saying off under the tac...it will turn the rear traction control off but not the front.
  5. Jul 11, 2010 at 10:58 AM
    jaredm85
    jaredm85 Member
    Colorado
    07 Tacoma Double Cab Short Bed TRD Sport
    x2
  6. Jul 11, 2010 at 11:03 AM
    TacoVerde
    TacoVerde Well-Known Member
    Sean
    So Cal
    09 PreRunner
    URD short shifter, OBX racing pedals and titanium/carbon fiber shift knob, Rear speaker mod, Taco bed mat, Bed extender, taco door sill protectors, Black TRD floormats, AFE stage 2 CAI, Doug Thorley Header and Catback, Glassworks Unlimited front fenders/bedsides, Engage front LT kit,2.5x8 King co's with resi's, dj straps
    that happens when i try to slide the corner to my house lol i don't know about your truck but on mine there is a button on the left dash with the traction control icon and i just hold it in at a stop for five seconds and it turns it off. that stability control crap won't let you do donuts either it cuts the motor
  7. Jul 11, 2010 at 11:07 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    It is in the owner's manual as well... Press the button to the left of the steering wheel that is a car with wavey lines (skids) under it, and hold it down for a few seconds. The VSC OFF light will indicte you are in open differntial mode with both TRAC and VSC in OFF mode. However, if you get crazy and the computer thinks it needs to to save the car, it will turn the VSC back on!
    By-the-way, a quick push of the button turns on the AUTO LSD for a posi-traction-like limited slip.
  8. Jul 11, 2010 at 2:42 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    x1000
    We all have drive on the road with you too. Would like it to be safe.
  9. Jul 16, 2010 at 8:53 PM
    Apexhntr
    Apexhntr Member
    Doug,
    I had an X5 and you could but it on the edge and just throttle steer for hours with out any interference. Two Porsche 911s and Two M3s all had stability control but it was refined and not intrusive. The 2010 Tacoma is such a pussy if there is a sight dip before a turn or decreasing radius turn the fun nanny kicks in for no reason...it is just too bad the Germans don't make pickups.
    Otherwise good quality from Toyota... but a piss poor VSC attempt on their part. We have very curvy roads in the mountains here. Today the VSC kicked in going around a 55mph turn...always kicks in on right turns(not left?)...it pulled me into the on comming traffic...not cool!
    Bob in NC
    PS The previous owner had the truck into the dealer 6 times for VSC issues and traded it so I found out later.
    I'm thinking or trading it after one month and 4 visits to check and recalibrate the VSC.
  10. Jul 16, 2010 at 8:56 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Your VSC only kicks in easily on right turns too ? I thought that was my gremlin .
    Very interesting ....
  11. Jul 16, 2010 at 9:11 PM
    Apexhntr
    Apexhntr Member
    The VSC on my truck is screwed up...the sensor thinks the vehicle is about to skid when its not. The computer in some trucks with VSC systems must have a glitch because "safe" situations set it off. The problem is that it causes my truck to unexpectedly veer to the left-now an "unsafe situation". Only right hand turns cause this to happen.
    33 years driving motorcycles and cars from 1960s-2010 NO ACCIDENTS or TICKETS and the Tacoma is IMO unsafe and the dealer has not been able to sort this out.
    For what its worth, once your out of the mountains and the roads are level and straight...no issues. It is not a simple matter of just driving too fast there is an evevation component to this situation which seems to fool the sensor.
  12. Jul 16, 2010 at 9:13 PM
    OZ-T
    Peter North
    British Columbia
    I agree , I have had a mystery " right hand turn only " VSC engagment issue since I got the Tranny TSB ecu re-flash done . The VSC engages when I am driving at 40 MPH , not crazy speeds , and I have a stock suspension .
  13. Jul 16, 2010 at 9:19 PM
    Apexhntr
    Apexhntr Member
    There must be a few of the same gremlins out there.
    I had an engineer suggest checking the distance between the wheel sensor and the pickup. He thought the distance should be as small as possable...this could be why other folks are not having issues-theirs are in spec. Thats the next step to remove the left front wheel and have a look. Has any one else tried this?
  14. Jul 16, 2010 at 10:57 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    there must be a wire we can snip to turn this off, i drive some crazy mountains and i cant even go around a turn at 25 mph without it going off and sending me into the other lane, very scary and not cool at all!
  15. Jul 16, 2010 at 11:14 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    it shouldnt go off when your just going around a turn under the speed limit it scares the hell out of me every time too
  16. Jul 16, 2010 at 11:48 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    ive gotten into the practice of just turning all that crap off as soon as I get in the truck everytime unless its raining...
  17. Jul 16, 2010 at 11:50 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    well when you turn it off it only turns the rear off and not the front
  18. Jul 17, 2010 at 4:57 AM
    Apexhntr
    Apexhntr Member
    I turn it off but VSC is not fully off it...same problem on right hand turns. Why would you need to go slower one direction then the other. I drive back in forth on the same roads-frustrating.
    My wife has a 2008 4 runner it is fine on the same roads???
    No VSC engagement in 36,000 miles on her 4 runner. My truck 3X in 10 miles-every day. Note same driver, same roads different truck?
  19. Jul 17, 2010 at 7:38 AM
    CtTaco
    Eric
    Connecticut
    hmm...whenever mine acts up and i turn it off, it stays off...gotta be in a problem in the ecu somewhere then...you could always unplug the front abs sensor and kill everything too i suppose. not the best solution though. have you tried a new dealer and taken them on the road that does this consistantly? even if you had to pay them, it would be worth it..
  20. Jul 17, 2010 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Quit driving like an idiot on the street. If you are a "profesional", then you should know to keep that kind of driving on the track. If you want to slid your truck off road, fine.
