abs & traction control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Birdogsetter, Jun 22, 2024.
  1. Jun 22, 2024 at 11:22 AM
    Birdogsetter
    Birdogsetter [OP] Member
    09 Tacoma
    I had a fortune brake line break and I replaced it and bleed brakes...
    .. But now I have a abs and traction control light on... Have had oriellys and autozone scanners hooked up to but they show no codes and can't clear the lights... Any help would be great
    ...Thanks
  2. Jun 22, 2024 at 2:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You need to have it scanned with a scanner capable of pulling ABS codes.
    Still can't believe most Auto parts stores aren't using an ABS compatible scanner.
    Imagine all the extra money they could make sell you the wrong parts.
  3. Jun 22, 2024 at 6:05 PM
    Birdogsetter
    09 Tacoma
    I did have it scaned at a bodyshop that had a scanner that's suppose do it all but all of the scanners said there were no codes found, and I'm not having any problems except the 2 lights are on... Trucks only got 38569 miles on the clock....
  4. Jun 23, 2024 at 2:07 PM
    Birdogsetter
    09 Tacoma
    Have scaned with 3 scanners and all show no codes found.... I just want the darn lights off....
  5. Jun 23, 2024 at 3:01 PM
    TnShooter
    Deogee
    STOCK
    I'm still questioning the ABS codes.
    You can pull them yourself. But it really helps if you know hot to read them.
    And that can be better leaned with someone with experience showing you how to count the clinks.
    Not even Toyota can get it right in the manual. (Let's see if @Dm93 can spot the "wrong" in the FSM diagram below. :facepalm:)
    Anyways, you can give it a shot. I really think you have codes stored.
    You can have a look at the whole file below if you want to "learn" the system.
    Dm93 likes this.
  6. Jun 23, 2024 at 8:27 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That looks like something I would do, I'm terrible at writing and typing.:rofl:
    TnShooter[QUOTED] likes this.
