ABS triggering after cv boot replaced and new uca
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jdosumu, May 2, 2016.
  1. May 2, 2016 at 10:37 AM
    Jdosumu
    Jdosumu [OP] Member
    I just finished replacing my cv boots for the porsche 930 boots, and at the same time I installed the Icon UCAs. Now when I drive, my ABS triggers for no reason. What could be wrong? I'm guessing it could be a speed sensor as I took both of them out during the work, but how can I test the speed sensor?
  2. May 2, 2016 at 10:38 AM
    Large
    Large Red
    You're saying ABS .. could it be something else? What is the truck doing? Any dash lights on?
  3. May 2, 2016 at 10:42 AM
    Jdosumu
    Jdosumu [OP] Member
    No dash lights, every time I hit the brakes my ABS cycles, and its on dry pavement, no wheel slipage.
  4. May 2, 2016 at 5:31 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    1, did you lose the abs ring?
    2, are the axles are fully inserted into the wheels and torqued to spec?
    3, if you unplugged the sensors, did you forget to plug them back in, or all the way in?
    4, did you not tighten the sensors to the knuckle?
    5, did you clean anything involving the ABS, and if so, with what?
  5. May 2, 2016 at 7:52 PM
    Jdosumu
    Jdosumu [OP] Member
    So I just
    I just went through a similar checklist before I came in and saw this, so:
    1. No
    2. Yes
    3.I think this was my problem (I didn't work the sensors back in fully)
    4. Yes
    5. Yes, just a microfiber.
    Like I said, I think the first time I plugged the sensors back into the knuckle I didn't work it in fully to where the seal was nice and tight because when I just went back to check it they came out MUCH easier than the first time. So I just wiggled them in til they were nice and tight, I'm going to test drive it tomorrow and find out if it worked. Thanks for the input, I'll let y'all know if it worked.
  6. May 3, 2016 at 7:51 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Im having this issue...not everytime i hit the brakes but its happening. .... Happened after i replaced inner/outer tie rods, and lbj's
  7. May 3, 2016 at 1:01 PM
    Jdosumu
    Jdosumu [OP] Member
    So it did end up being the sensors not plugged into the knuckle far enough. When I first reassembled them, I pushed them what I thought adequately in there, but when I went back I realized they were far too easy to pull out. You really need to work them in there by turning them back and forth as you push. I'd say go back and check yours, you don't even have to take the wheels off. Dope build btw.
  8. May 3, 2016 at 2:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    sweet! I'll double check.
    Thanks brotha, I love The Tank!! lol
