ABS VS Non ABS Axle Shaft Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by RLD831, Oct 22, 2018.
  1. Oct 22, 2018 at 5:13 PM
    RLD831
    RLD831 [OP] Active Member
    Rob
    2001 Tacoma Doublecab PreRunner Limited
    I am looking to replace the passenger side axle shaft and backing plate on my 2001 6 lug Prerunner. It does have the factory E-locker housing and the truck originally came with ABS. The ABS system is completely removed, so I don't care if the axles work with ABS or not.
    Can I install a Non ABS rear passenger axle shaft into a Prerunner E-locker housing that originally came with ABS? I don't see why it wouldn't work, the space the tone ring occupies should just remain an open space, but I wanted to double check to make sure the shafts are the same size and length otherwise, and that the seals would still seal.
  2. Oct 22, 2018 at 6:33 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Nope, the e-locker housing has a 21(?) spline shaft, the open diff housing has a 27 spline shaft. You have to use a shaft for an e-locker housing, although you don't need to keep the skid control rotor (aka tone ring) if you're not using ABS.
  3. Oct 23, 2018 at 5:34 AM
    RLD831
    Rob
    It says it fits a 6 cylinder Prerunner without ABS. Wouldn't that mean it's from an e-locker housing? Is the ABS and non ABS shaft for the e-locker housing the same minus the tone ring?
    Thank you for your help.
  4. Oct 23, 2018 at 7:12 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    No, a shaft for a prerunner w/out ABS doesn't necessarily mean it's an elocker axle. You need to ensure the type of shaft it is (spline count) before determining if you can use it in your axle housing.
    Yes, the shafts are otherwise the same between ABS and non-ABS. Just need the right spline count for the shaft to fit in the diff carrier.
  5. Oct 25, 2018 at 10:52 AM
    RLD831
    Rob
    I called another place that has an axle with 29 splines. That doesn't match either of those numbers. Is there a resource on here for looking up the actual numbers? I can't seem to find a definitive answer. I may have to pull mine out to check, but I'd rather only have to take it apart once.
  6. Oct 25, 2018 at 11:46 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah I’m probably screwing those numbers up. @Speedytech7 you know the axle spline counts off-hand between elocker and open diff?
  7. Oct 25, 2018 at 11:47 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sorry I dont, 29spline sounds right but there might be a 27spline too
