ABS wheel sensor Expensive
Discussion in 'Technical Chat' started by bowzerdoo77, Oct 11, 2010.
  1. Oct 11, 2010 at 2:56 PM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    OCEANSIDE, CA
    2016 DBL CAB 4x4TRD OFF ROAD
    6 inch Pro comp Stage 1 lift 305/70/18 MasterCraft MXT 18x9 Monster wheels,
    Ok i searched on the site to see if anybody had replaced this tiny ass little part. i had code 32 which is that i priced it it is like 230 -260 dollars. does anybody know where you can get that for less than that thats a shitload for what it is.. it takes 30 secondes to get it off how can it be that much
  2. Oct 11, 2010 at 10:47 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    That's how much they cost. Haven't been able to find them much cheaper anywhere. I had one crap out on me a few months back.
  3. Oct 12, 2010 at 5:36 PM
    bowzerdoo77
    OCEANSIDE, CA
    so as sson as you change it does it clear the abs code
  4. Oct 13, 2010 at 8:52 AM
    gobias
    02 Dbl TRD
    I unplugged the battery and reset the ECU after I installed the new one just in case.
  5. Oct 13, 2010 at 8:56 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    wheel sensors are pretty pricey. i had to change 2 of the rears on my gf's TL and each one cost $200...
    lesson learned... dont use "Fix A Flat". its not "tire sensor safe" as stated on the can!!
  6. Nov 27, 2010 at 7:43 AM
    bowzerdoo77
    OCEANSIDE, CA
    ok so i changed the sensor and the light was still on.. i took it to the dealer and they puuged it in and it was the wire from the ecu to the sensor it was ony 55 bucks and the sensor that was not even bad cost me 215.. so if your light goes on go have it checked before you self diagnose it.. that woud have saved me 215 bucks.. the wire got streched out when i hit a bump.. and it was broken inside somewhere that i couldn't see.
