ABS wires???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PAlittlematty, Nov 7, 2011.
  1. Nov 7, 2011 at 8:30 AM
    PAlittlematty
    PAlittlematty [OP] "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow 4" bracket and 35s. MC rear AP front bumpers 5.29s locked
    Broke mine when I was doin my lift. No LSD now and my ABS light is on. Can't be inspected with the light on so I hafta fix em ASAP. Cheapest place to buy em? Local dealership quoted me $60 and $72.
  2. Nov 7, 2011 at 11:02 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    i had the same problem on mine once the harness is very easy to repair, unplug it from under the hood and take out the 2-4 bolts holding the harness in and unplug from the brake sensor this whole process takes about 5 min including taking the wheel off. when you have it off you can cut off the ruber tube over the wires just make sure you have a long piece of heat shrink tube to put back over it when i got mine apart i soldered the very small broker wires back together and covered the entire harness with heat shrink tube it took about 30 min and cost about a dollar.
  3. Nov 7, 2011 at 12:04 PM
    PAlittlematty
    Beech Creek, PA
  4. Nov 7, 2011 at 12:22 PM
    PAlittlematty
    Beech Creek, PA
    So there are 2 small wires in each harness? And are these wires covered with a coating inside the tubing?
  5. Nov 7, 2011 at 12:24 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    yes
    two insulated wires inside the outer tubing. really easy to fix.
    its easy to find the break because the tube is usually skinny where the break is
  6. Nov 7, 2011 at 12:25 PM
    Yoytoda
    Roland
    completely stock
    i unplugged mine to disable the damn ABS
  7. Nov 7, 2011 at 12:32 PM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
  8. Nov 7, 2011 at 1:28 PM
    PAlittlematty
    Beech Creek, PA
    Id like to disable mine but my LSD runs off the wheel speed sensors
  9. Nov 8, 2011 at 5:25 AM
    PAlittlematty
    Beech Creek, PA
    Got it fixed. One wire broken on the drivers side. Ill ordedr a whole new wire sometime soon. Just had to fix it for inspection
  10. Nov 8, 2011 at 8:22 AM
    Yoytoda
    Roland
    completely stock
    yea, i know. but i installed a locker...
  11. Nov 8, 2011 at 8:33 AM
    PAlittlematty
    Beech Creek, PA
    That's comin too
  12. Nov 8, 2011 at 8:53 AM
    TacticalBacon13
    Dunk
    Beech Creek
    lies!
