ABS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cody69, Nov 7, 2017.
  1. Nov 7, 2017 at 2:16 PM
    cody69
    cody69 [OP] Member
    2007 Tacoma 4WD Longbox
    I am wondering if my ABS is working the way its supposed to. When I brake on a slippery surface and the ABS kicks in it makes a grinding type of noise. Is this normal?
  2. Nov 7, 2017 at 8:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes, it is normal.
    It isn't really "grinding". What you hear is the solenoids cycling the pressure to the brakes at a very high speed. This achieves the highest braking pressure without a wheel lockup so that you can steer the vehicle around an obstruction rather than hit it. ( Note: a locked front wheel will not steer ).
