Abs
Discussion in '1st Gen. Tacomas (1995-2004)' started by cumminsdiesel, Dec 27, 2009.
  1. Dec 27, 2009 at 1:41 PM
    cumminsdiesel
    cumminsdiesel [OP] Well-Known Member
    Alex
    Brecksville, Ohio
    Toytec coilovers, skyjacker leaf springs.
    I tried to find a solution before posting but I could not find one. If I am driving on dry pavement (or even in the snow), no matter how easily or hard I stop, my ABS kicks on. I was curious why this is doing this. Front brakes just changed.
    Thanks in advance.
  2. Dec 27, 2009 at 1:44 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Perhaps you should lay off the gas pedal when coming to a stop. The only time I had the ABS kick in on dry was when I was going down a hill and stopped way to late. (First week of owning the '09) Other than that, I get it when there is a skid detected on slick surfaces.
  3. Dec 27, 2009 at 1:47 PM
    cumminsdiesel
    Alex
    Brecksville, Ohio
    Yeah but the thing is, it happens whether I stop 10 feet from a light or 50 feet. No matter what.
  4. Dec 27, 2009 at 2:27 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    Dunno then, could be whatever controls the ABS is starting to crap out. That sucks if that is the case. Godd luck figuring it out.
  5. Dec 27, 2009 at 3:13 PM
    cumminsdiesel
    Alex
    Brecksville, Ohio
    The thing that is weird, is the BRAKE light never flashes or comes on. Not familiar with foreign vehicles, just looking for some insight in trying to solve the annoying sound as well as wearing out ABS system.
  6. Dec 27, 2009 at 3:18 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Does it stay on the whole time you stop or just come on for a second.
  7. Dec 27, 2009 at 3:19 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    since you just changed your front pads make sure your wheel speed sensors are working right, more often than not loose metalic particals from changing brakes will contaminate the wheel speed sensors (magnets) causeing it to kick on ABS every time you hit the brakes
  8. Dec 27, 2009 at 9:16 PM
    cumminsdiesel
    Alex
    Brecksville, Ohio
    Makes sense, it just goes on for a second or so and shuts off. Where is the location of the speed sensor?
  9. Dec 27, 2009 at 10:57 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    ill check with mine later and follow up since it is 2am, but it should be the only electricle peice and it has a clip close to the rotor
