Absolutely no power - alt / battery new
Discussion in '1st Gen. Tacomas (1995-2004)' started by ericamf, Jan 10, 2024.
  1. Jan 10, 2024 at 10:06 PM
    ericamf
    ericamf [OP] New Member
    Erica
    1996 Green Tacoma V6
    I have a 1996 tacoma V6 5spd. Alternator went out, swapped it out and it ran great for 4 days. Out of nowhere was completely dead again. Was able to jump it initially. Had battery tested and it was overcharged so they replaced, also tested brand new alternator and it was testing perfectly as well. All fuses and relays are intact. I replaced the battery terminals as well as the ground wire. There is absolutely no power and will not jump anymore. No cabin lights or anything, no cranking or literally anything when turning key over. Anyone have any thoughts?
  2. Jan 10, 2024 at 10:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ericamf[OP] likes this.
  3. Jan 10, 2024 at 10:14 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you certain the main 80 amp alternator fuse isn't blown?
    Easy way to check, see if you have power at the ALT-S Fuse (7.5A).
    ericamf[OP] and TnShooter like this.
  4. Jan 10, 2024 at 10:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you getting power to the post in the fuse box where the cable bolts to the fuse box?
    ericamf[OP] and Dm93 like this.
  5. Jan 11, 2024 at 6:52 AM
    Glamisman
    Glamisman Well-Known Member
    Which battery ground did you replace? There are 3 on a Tacoma. Battery to block, Battery to inner fender and back of passenger side cylinder head to firewall.
  6. Jan 11, 2024 at 11:48 PM
    ericamf
    Erica
    Update:
    The 80A was in fact bad when tested. I swapped that out as well as the positive to fuse box connection just because it looked a bit musty when I got in there to remove the fuse. Right after replacing the fuse I had internal power; all cabin lights and dash lights were on and the power locks worked. I let it sit for a few before trying to crank. Gave me one click and then lost all power completely again. Battery is reading high at 12.95-13V now.
    now what…
  7. Jan 12, 2024 at 12:39 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Blew the 80A, again?
  8. Jan 12, 2024 at 12:53 AM
    ericamf
    Erica
    Visually looks ok but didn’t test again yet, going to in the morning. Needed to step away from the truck for the night LOL
  9. Apr 3, 2025 at 3:57 AM
    Brangus
    Brangus Member
    Hi, my 2001 just developed the same problem: no electrical power anywhere on the truck. Did you ever fugure out a fix ?
  10. Apr 3, 2025 at 4:04 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  11. Apr 3, 2025 at 4:34 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Sounds like there is a short in either the ignition or in the starter that is causing the 80a to blow. I would guess the 80a is blown again.
