AC 12 inch sub custom box!
Discussion in 'Buy / Sell / Trade' started by JStradaXR, Aug 23, 2011.
  1. Aug 23, 2011 at 11:10 PM
    JStradaXR
    JStradaXR [OP] Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
    Finally the moment of truth came i got a 12 inch sub to fit in the ac custom box..
    this one is the product, once you order ill wrap it in either suede or vinyl your choice
    it has to be vertical if i put it horizontal the seats will not recline at all
    vinyl 235 + shipping
    suede 265 + shipping
    and also im including other pictures of what ive done in the past as a
    reference
  2. Aug 23, 2011 at 11:40 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    if you can get two 12's to fit ill buy one.
  3. Aug 24, 2011 at 12:33 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    You dream it I can build it!
    Were are u located?
  4. Aug 24, 2011 at 1:59 AM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    2 shallow mount 12's like in the first box would be pretty sweet.
  5. Aug 24, 2011 at 11:51 AM
    Shemicals
    Build Page
    no i want to mount my two diamond 12" d3 deep mount subs. reverse mounted
  6. Aug 24, 2011 at 12:17 PM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Reverse mounted, why may I ask ?
  7. Aug 24, 2011 at 9:19 PM
    Shemicals
    Build Page
    how else are you going to fit 2?
  8. Aug 25, 2011 at 11:53 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Not unless there shallow mounts...and im going to try and build a vertical standing box.
  9. Aug 29, 2011 at 12:15 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Bump.....
  10. Aug 29, 2011 at 7:42 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    That is one sweet enclosure!!!! Have something for the DC?
  11. Aug 29, 2011 at 7:47 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Very impresive how you made the sides look so sleek, I also did this with my sub enclosure.
  12. Aug 29, 2011 at 9:14 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Not yet , I don't own a dc so its kinda hard to build it not having one. But maybe ill ask to borrow someone's
  13. Aug 29, 2011 at 10:10 AM
    Shemicals
    Build Page
    make one that can house two 12" subs while still allowing passengers to sit in the back and i want it.
    if you cant do that i may buy this one
  14. Aug 29, 2011 at 10:43 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    i can build it, someone buying, reason being its just for one customer. so i have to build from dead scratch, and not like the other ones were i have templates and i can build them quickily. but just like any custom order it might be a little more pricy. if you want it ill build it ?:D
