AC 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kslidegg6, Jul 2, 2025 at 4:08 AM.
  1. Jul 2, 2025 at 4:08 AM
    Kslidegg6
    Kslidegg6 [OP] Member
    Saturday
    Kyle
    2019 trd off road
    None yet
    It’s been in the 100’s lately and I feel like my AC isn’t blowing as cold as it should be. Any recommendations on where I could start or what I should do first? Any help would be appreciated.
  2. Jul 2, 2025 at 4:53 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I would get a can of refrigerant and top it off. It’s quick. And less expensive than having a shop do it. Be sure you get the correct one as there are a few different ones
  3. Jul 2, 2025 at 4:59 AM
    Kslidegg6
    Saturday
    Kyle
    2019 trd off road
    None yet
    What’s the correct one?
  4. Jul 2, 2025 at 5:05 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    You can open the hood and there is a yellow tag, mine is R 1234yl
  5. Jul 2, 2025 at 5:06 AM
    Kslidegg6
    Saturday
    Kyle
    2019 trd off road
    None yet
  6. Jul 2, 2025 at 5:10 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Get a hose and guage included, you’ll need to know the level. Note it isn’t cheap. Like $50
  7. Jul 2, 2025 at 5:27 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't reccomend this unless you know what you are doing, you can easily overcharge a system especially without being able to see high side pressure.
    If you do go this route don't get any that has stop leak, leak sealer, or says "seals leaks" on it, that stuff will wreck an A/C system if any moisture or air ever enters the system, you want to use pure refrigerant.
    Chew likes this.
  8. Jul 2, 2025 at 5:53 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Pick up a set of gauges and check pressures.
  9. Jul 2, 2025 at 10:51 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There was a TSB for AC not blowing cold enough, it actually added an electric fan
  10. Jul 2, 2025 at 11:59 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    What is the tsb#. And what years did it effect
  11. Jul 2, 2025 at 12:21 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    shakerhood likes this.
