AC Adapter power loss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06BLUEDBLSPORT, Nov 11, 2009.
  1. Nov 11, 2009 at 5:52 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT [OP] Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    My AC adapter in the dash has faulty wiring i think. When i plug my GPS into the Ac adapter (not the cigarette lighter) the GPS screen has a message that pops up saying something about power disconnection would you like to run on battery or turn off, then it suddenly just goes back to doing its thing. And my iphone charger has a bright light on it that lights up when plugged in, i noticed that thing flickers and dims then shuts off, then my iphone lights up because its no longer charging, then the cell phone charger lights up like power is flowing thru it and my iphone says its charging again. It does this every time i use it. If what i typed above is alittle confusing tell me, but i hope who ever reads this gets what im taking about. The question is...is the wiring faulty on my AC adapter?
  2. Nov 11, 2009 at 6:09 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    so no one here is good at this electrical stuff...wow
  3. Nov 11, 2009 at 6:12 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    if you use it too much, maybe it has a small short on the contact plates (if thats what they are called anyway)
  4. Nov 11, 2009 at 6:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Peace be on your brother- 16 mins is hardly enuf time to get worried about bumping your thread about not getting answers.
    My guess is you have a bad ground or a loose cable/fuse.
  5. Nov 11, 2009 at 6:15 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    where would those wires be that causing a short? It wouldnt be the alternator would it, just putting it out there cause one of my friends said that could be a problem
  6. Nov 11, 2009 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like a wire is comming loose. Check the wires behind the socket, and make sure they are intact, and pluged in propperly.
  7. Nov 11, 2009 at 6:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Alternator would give you problems with everything....You'd get lights dimming and coming back, probably a CEL too fi it was that bad. My guess is the wires are loose between the fuse block and the socket.
  8. Nov 11, 2009 at 6:24 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    how would i access those wires?
  9. Nov 11, 2009 at 6:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Gotta open the dash up....
  10. Nov 11, 2009 at 6:31 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    do i need to pull out the ac controls and pop out the radio and etc? couldnt i just pull out the ac adapter?
  11. Nov 11, 2009 at 6:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wait....You have an A/C adapter in your dash?? Or are you talking about the DC outlet?
  12. Nov 11, 2009 at 6:35 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    i dont the correct term for it but you know the circular things where you plug in gps's and chargers. the two power outlets underneath the A/C controls
  13. Nov 11, 2009 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....I dont think they pull right out. Like Brunes said, you have to take the dash apart.
  14. Nov 11, 2009 at 6:44 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    when you say apart, do you mean like radio and A/C controls pulled out and all that fun stuff
  15. Nov 11, 2009 at 6:50 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    the ac adapters make a modified sine wave not a true sine wave, this causes problems with electronics. Modified sine waves are squared and notchy version of a "curvy" regular sine wave and dont have the same RMS values. THis most like is the problem
  16. Nov 11, 2009 at 6:51 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think you'll actually end up having the remove the shifter console...cause that whole section is one piece IIRC.
    (But I haven't seen my Taco in like three weeks...so I'm not sure...)
  17. Nov 11, 2009 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hes talking about the DC out put in the cab.
  18. Nov 11, 2009 at 6:53 PM
    Tacoyota
    08 4wd
    can you run a cigarette lighter (DC) to the GPS? or you talking about an AC adapter you plug into ths same (DC) round outlet?
  19. Nov 11, 2009 at 6:53 PM
    Tacoyota
    08 4wd
    oh ok, I thought he said AC
  20. Nov 11, 2009 at 6:53 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    You beat me to it...was was gonna request pics of the said AC adapter in the dash because thats a new one to me!
