AC air blend actuator/ controls issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Otterbean, Oct 13, 2023.
  1. Oct 13, 2023 at 10:19 AM
    Otterbean
    Otterbean [OP] New Member
    Curtis
    2003 Toyota Tacoma Prerunner Extra Cab
    2003 Tacoma 2.7L prerunner extended cab automatic transmission vehicle
    My AC isn't blowing as cold as I like and the actuator is just turning on and off even when the AC or heat isn't turned on.
    I took the actuator off and tried to push the horizontal metal rod that runs toward the center console and controls that the actuator actually pushes, but it is very difficult to move.
    The AC works, but I'm thinking that perhaps the reason has something to do with the controls. Anybody have any experience with this?
  2. Oct 13, 2023 at 4:54 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    My 04 acted up...ended up being the control panel thing that had the climate control knobs on it..can't remember the part name. I replaced the blend door actuator first and didn't fix it
  3. Oct 13, 2023 at 6:56 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    HVAC Temperature Control panel
    55910-35240
  4. Oct 13, 2023 at 8:12 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Don't know how to solve it being difficult to move. However I had a wire get tangled in my blend arm (how, I don't know) and it would open and close and open and close, I could hear it. Finally tore it apart and found the culprit. All in all, if it is stiff for some reason I would assume it could cause a similar issue of it opening and closing.
  5. Oct 18, 2023 at 3:58 PM
    Otterbean
    Curtis
    Ended up taking it in to a mechanic I trust in town. The bill is coming in at $1425. I'm curious about what is being replaced. I did request a new compressor as the bearing was failing on it and it did sieze. We will see how it turns out.
