AC Blower always on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMack80, Sep 9, 2010.
  1. Sep 9, 2010 at 6:29 AM
    TacoMack80
    TacoMack80 [OP] New Member
    Justin
    Annapolis
    2010 SR5 Debadged
    Sunroof, Nerf Bars, Tool Box, GPS/Stereo
    I did a quick search on this and didn't see anything.
    I've had my '10 Tacoma for nearly a year and can't remember noticing this, but my AC blower (or heat for that matter) seems to be always blowing air. Even when it's in the off position.
    This is my first Toyota (love it), but is this common?
    My old jeep used to have a little air going through it at all times.
    Thanks
  2. Sep 9, 2010 at 7:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If the HVAC air control is on the vent setting, its normal for air to still come into the cab. Set it to the Recirc setting if you dont want that to happen.
  3. Sep 9, 2010 at 7:38 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '10 Access SR5 4x4 4cyl
    Are you saying air is always coming through the vents? In which case, see above.
    If you are saying that your fan is actually blowing even when the fan speed is set to off, then you have some kind of an electrical or switch problem. To check your fan, sit in your Tacoma in a quiet place like a garage, and set the key to accessory, then adjust your fan speed at the dash dial and listen to the difference in fan sound through the various speed settings. Pay particular attention to any sound when the fan speed is set to off.
    Give us an update.
  4. Sep 9, 2010 at 1:22 PM
    TacoMack80
    Justin
    Annapolis
    2010 SR5 Debadged
    Just checked. I guess I'm a knucklehead.
    When off, in accessory, no fan.
    I guess I didn't realize that the recirculation/vent works when in the blower is "off".
    I don't remember that working in that manner in my last vehicles.
    Thanks!
  5. Sep 9, 2010 at 1:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    and Welcome to TW! :)
