AC blower motor? Changed resistor and still nothing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Anthony, Dec 10, 2010.
  1. Dec 10, 2010 at 2:24 PM
    Anthony
    Anthony [OP] San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    06 tacoma 2.7L, no air on any speed, you can hear the compressor kick on n off, AC light turns on just nothing comes out of the vents. Just did the blower resistor swap and still nothing.
    Blower motor itself Im guessing? :(
  2. Dec 10, 2010 at 2:38 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Did you check the heater fuse?
  3. Dec 10, 2010 at 2:42 PM
    Anthony
    fuses are fine. was working fine then i got back in the truck and it stopped. over the months its done this several times but if you gave it a good smack itd get going again... but no such luck.
  4. Dec 10, 2010 at 2:44 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Sounds like bad brushes or a loose wire.
  5. Dec 10, 2010 at 4:48 PM
    Anthony
    inadvertently knee'd the glovebox and it started blowing out again
  6. Dec 10, 2010 at 7:50 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Start simple, isthe wire connector to the fan on good? It's easy to get to from underneath the dash.
  7. Dec 10, 2010 at 11:44 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Happened to me where I had to hit it to work and finally took the motor out and cleaned the blower motor with MAF cleaner spray and haven't had a problem since.
  8. Dec 11, 2010 at 7:08 AM
    Anthony
    thanks for the tip, i was JUST thinking if MAF spray would clean it.
  9. Dec 11, 2010 at 12:08 PM
    Gadvan
    Gadvan Well-Known Member
    cincinnati,ohio
    v6 SR5 TRD
    Theirs a thread on fan speed not working stickied. Mine does it too I bought a new resistor and problem has stopped but I knoe the harness can get s burnt spot on the connecter not big enough wire for the power.
  10. Dec 16, 2012 at 10:38 AM
    toddm7
    toddm7 New Member
    05 Tacoma
    Thanks so much for this info! I tapped the motor near the shaft end with a small hammer & the blower started working again. At first it ran slow .. so with about a dozen light taps it finally got up to full speed.
  11. Dec 16, 2012 at 10:45 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD OffRoad Poser ψ(`∇´)ψ
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Check and make sure the connector isn't burnt. Yea it's working now, but it could be that it's shorting out, and it could potentially cause a fire. Never hurts to be thorough.
  12. Dec 17, 2012 at 3:30 AM
    toddm7
    toddm7 New Member
    05 Tacoma
    I appreciate that ... thank you. The connector was the first thing I checked & cleaned. The motor may need to come out & be cleaned as someone else mentioned. But for now it is working just fine.
