AC Blower Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 8th sin, Aug 27, 2010.
  1. Aug 27, 2010 at 6:58 AM
    8th sin
    8th sin [OP] Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    I know there's a couple TSB's out for noisy HVAC components, but I'm not sure mine falls into the same bucket. On any fan setting, I get a high pitched rapid clicking sound, that will increase as I increase the fan speed. It is annoying as hell, and now that I've noticed it I can hear it even with the radio cranked up...my girlfriend doesn't hear it all. It sounds as if the blades of the fan are striking something since I can hear it spin up and spin down as I adjust the fan. I've only tested on full cold with recirc (I live in Texas, so testing it at any other temperature is out of the question. I WILL autoignite and die), but it seems alot of guys are reporting the problem when cycling to heat and/or defrost. Truck is a 2010.
    It's under warranty I know, but I really dont want the techs ripping apart my dash chasing the problem. Anyone else have this issue?
  2. Aug 27, 2010 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Open the filter and see if there is debris in it. Maybe pull the fan down, and see if there is something in there...
  3. Aug 27, 2010 at 7:30 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    x2. Sounds like a leaf got past the filter (or they forgot to install your filter) and is catching on the fan blades.
  4. Aug 27, 2010 at 7:50 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    thanks, I'll check it out this afternoon. It does sound like something catching on the fan, but I can't imagine how something would have gotten in there. I park in the garage at home and in an open lot at work during the day.
  5. Aug 27, 2010 at 10:10 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    Filter was clean and there was no debris. That's definitely where the sound is coming from though and if i turn the fan by hand I can find the spot where it squeaks. At the risk of stinking up my truck, I'll probably just drop the blower this weekend and lube it up.
  6. Aug 27, 2010 at 10:33 AM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    I'm having the same issue with my 2010 Tacoma. I only notice the high pitched clicking noise when the AC is on. I havent tested to see if I hear it with different settings or with the heater or defrost on. It has a sound when you hear a CD skip through tracks. I havent been able to track down exactly where the sound is coming from. I have checked the filter and it was clean. I was going to continue to troubleshoot it this weekend.
    That noise is really starting to get annoying though it seems quiet when the radio volumn is off... i can still hear the high pitched sound when the radio is turned up.
  7. Aug 27, 2010 at 10:44 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    +1 here, my 09 does the same, loud enough to hear it over the radio. Filter is clean and there is no debris in the fan. Tried the balancing screws mentioned somewhere else in the forum, but mine seem to be thread locked and wont budge.
  8. Aug 27, 2010 at 11:04 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    interesting...yea, I would describe the sound not so much as a CD skipping but that teek teek teek teek teek teek you sometimes get when you burn an audio CD too fast. Pull out your glovebox, remove the filter, and reach in and turn the fan with your fingers (make sure it's off!). You should be able to hear where it's making contact.
    it is annoying as hell though, my 06 never did that. I need to find some time to take my truck in so they can register my new TPMS sensors and I'm going to start leaning on them about the TSB..If I can't solve the problem with some lube, I'll have them address this as well since it's obviously an issue with the blower assembly and wont require ripping out the dash.
  9. Aug 27, 2010 at 11:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If its a chirping sound, there is a write up on here on how to fix it.
  10. Aug 27, 2010 at 2:37 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Mine did that for a while then it started sqeeking really bad so I just replaced it..............simple fix......
  11. Aug 27, 2010 at 6:30 PM
    stormyday
    stormyday Well-Known Member
    Morganton, NC
    14 Taco Double Cab Pre-Runner
    I had mine replaced around 25K miles. One of the bearings in the fan was freezing up.
  12. Jan 3, 2011 at 10:05 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    Similar question to this thread, the fan in my '07 only ticks on low and medium but it is absurdly annoying. Once I turn it to high it goes away. Thoughts?
  13. Jan 3, 2011 at 1:24 PM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Rjclemen, mine is pretty much acting just like yours is. Ticks on lower speeds, but prettyt much gone on high......unless the air noise is over the ticking, making it less apparent.
  14. Jan 4, 2011 at 6:18 PM
    surfer4191
    surfer4191 Member
    NSB FL
    07 tacoma longbed
    DITTO!!! SO ANNOYING! WHERE IS THE THREAD ON THIS?!
  15. Jan 4, 2011 at 6:21 PM
    docktallent
    docktallent Member
    10 trd off road white
    18 inch moto metal 951
    i just took mine out and greased the the top bearing and bottom bearing on the motor and left it running for about 2 minutes and its not making a sound now.. if you dont want to try this im pretty sure its under warranty
  16. Jan 4, 2011 at 6:41 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    From all of my research on this problem, it seems to be confined to the fan motor assembly itself.... This is a very common problem, I am going to get it fixed tommrow.
  17. Jan 8, 2011 at 11:00 PM
    Baadboy11
    Baadboy11 Well-Known Member
    Lee's Summit, MO
    07 DC SB Offroad 4x4, 6spd
    Mines doing it too, any tips on lubing it?
  18. Nov 6, 2011 at 7:59 PM
    agarner59
    agarner59 Member
    Adam
    Knoxville/Chattanooga
    '10 PreRunner SR5 Doublecab
    Running Boards
    Comments #12-17, have any of you taken the truck into Toyota for service on the issue? My 2010 PreRunner's recently started doing the same thing. Ticking on low and low-med, but not really on the higher speeds. That ticking will eventually drive me insane. Any help is appreciated.
