AC blows cold on drivers side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bronze, Jul 7, 2010.
  1. Jul 7, 2010 at 12:47 PM
    bronze
    bronze [OP] New Member
    I have a 2005 and just had the AC recharged. It blows cold from the drivers vent but gets hotter at each vent going towards the passenger side. It is like the AC is on on one side and the heat is on on the other. Any ideas?
  2. Jul 7, 2010 at 9:21 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Sounds like you clogged your filter/drier when you recharged the system.
  3. Jul 7, 2010 at 10:21 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds like your expansion valve/orifice tube is sticking or clogged. The expansion valve/orifice tube regulates the amount of R134-A that enters the evaporator core which then regulates the temperature of the air coming out of your vents.
    ??? Did you recently replace your compressor? If so the debris from the failed compressor could have clogged the expansion valve.
    I just worked on a Ford Van that had this exact same problem and the expansion valve was clogged causing the air to blow warm on one side and cold on the other.
    Just to make sure, I don't think any Tacomas come with dual climate controls do they? If you had dual climate controls it could be a temp door actuator, but I don't think that's the problem.
    If your reciever dryer was clogged your a/c would not work at all and likely blow out a hose since it is on the high pressure side of the system.
    BTW I am an ASE certified tech for HVAC systems.
  4. Jul 7, 2010 at 10:54 PM
    Asgard
    ^^Could be the expansion valve also as the same thing happened to me a couple weeks ago. I took it to a shop and at first the tech was saying it's more than likely the expansion valve but after checking the system my expansion valve was good. Turned out to be the filter / drier element. Looks like this :
    I think the proper name for it is a "A/C Dessicant Element," sorry about that guys
  5. Jul 7, 2010 at 10:59 PM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    my air is only cold when i'm driving. warm when i'm idleing
  6. Jul 7, 2010 at 11:20 PM
    NelsonTacoma
    Tucson, AZ
    Excellent answer!!!!
  7. Jul 8, 2010 at 3:12 AM
    bronze
    So, is this something I can fix? I really don't understand how something outside the truck can cause a problem like this inside. Wouldn't the ac core inside the truck be cold causing the all vents to blow cold? No, it doesn't have dual climate control. The only work that has been done to the ac system was the recharge because it wasn't blowing cold. I could understand the dual climate theory of a flapper door being stuck or something. Can the "A/C Dessicant Element" be purchased at any place other than the dealer and can it be replaced without discharging the freon?
  8. Jul 8, 2010 at 3:01 PM
    Asgard
    When you recharge the system sometimes you stir up debris in the system and things get clogged. I would take it to a shop and let a tech look at it so he can pinpoint the problem. Here is a helpful link : http://www.blogautoparts.com/?cat=6
  9. Jul 22, 2010 at 9:56 AM
    OutbackHack
    OutbackHack Well-Known Member
    Redmond, WA
    2014 DCLB Heavy
    I had the same issue with the cool drivers side/warm passenger side vents in my 2010 Tacoma. Finally took it to the dealer to get fixed (after almost 2 months of +90 degree days without a good working AC) and they just recharged the AC and replaced an O-ring somewhere in the system and now it seems to be resolved.
  10. Jul 22, 2010 at 9:59 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    That sounds like a condensor fan issue. Might wanna check and make sure your condensor fan is working properly.
  11. Jul 22, 2010 at 10:02 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Hey Nelson, could the a/c dessicant element be the reason i'm getting warm air at idle and then when i'm driving it starts blowing cold air? Its almost like the cycle switch turns on for like 30 seconds when i'm idling then i can feel the compressor turn off, and i start getting hot air. Its really a pain because i can't chill in my truck at the Jack in the Box with my ac on because its starts blowing hot or warm air depending on the temp outside. I don't know what kind of maintainence my truck had before (i bought it used) so i really couldn't say whats going on. I would like to get it working properly since i just recently had a baby and I would like to have it on during the summer. Thanks!
  12. Jul 23, 2010 at 11:09 AM
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    Sounds like the A/C system is just a little bit low. May have a small slow leak. Put the correct amount in and it will be fine. Seen it many times..
  13. Nov 12, 2012 at 10:08 AM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    OCEANSIDE, CA
    2016 DBL CAB 4x4TRD OFF ROAD
    6 inch Pro comp Stage 1 lift 305/70/18 MasterCraft MXT 18x9 Monster wheels,
  14. Aug 25, 2016 at 6:42 AM
    burningflames
    burningflames New Member
    Dennis
    2009 Toyota Tacoma TRD 4x4
    none
    Greetings,
    My 2009 Toyota Tacoma air conditioner is blowing cold air on the left side and the right is blowing hot air. Can you say what causes this?
  15. Aug 25, 2016 at 10:49 AM
    CurtB
    CurtB Well-Known Member
    Curt
    Kansas
    2010 Tacoma SR5
    First thing to check is the refrigerant level, with a set of gauges.
  16. Aug 25, 2016 at 9:03 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Blower door? Might be getting stuck or something stuck in the vents. But I can't tell you, I've never ran across this issue.
  17. Sep 20, 2016 at 9:50 AM
    12345
    12345 1st time taco owner
    Wahiawa 96786
    2013 v6 2wd
    K&n intake/borla
    My 2013 is doing the same thing. I hope it don't cost an arm and a leg to fix.
  18. Sep 20, 2016 at 10:24 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    your charge is low. I had the same problem and recharged it. Now in 95 degree weather I rarely turn it above the low setting once I get the cabin cooled. Above 95 I will run it on the second for the most part.
  19. Jun 3, 2017 at 5:04 PM
    RCKYOTA
    RCKYOTA Member
    Shawn
    1984 x cab toyota rock crawler, 2006 trd dcsb v6 4x4 tacoma
    Crawler, locked dual t cases 37s hydro steering, built motor , everything, tacoma... stock for now !
    Have same issue looks like I need a recharge think a do it yourself kit will work or do I need the refrigerant completely changed out
